Old 07-01-2007, 04:11 PM   #1
alpineau
alpineau's Avatar
Default Auto Problem
Hey All
Well I was driving home last night and thought i would give the car a bit of a push so i went to drop the car back into 2nd but the gear box would not change. I tried first as well and the gear box still thinks it in drive, as i take off the car just keeps changing up no matter if it is in first or second or drive. Third holds it's gear and i can get into reverse no problem it's only first and second that seem to be effected. I don't know how long it has been like this because the last time i manually selected the gears like this was a week or so before and they were fine then.
The gearbox feels smooth and the changes feel normal just got no first and second gear selection. Does anyone have any ideas on what might be causing this
Thanks in advance for any help
Alpineau
OLD - 2000 AUII FUTURA 75TH ANNIVERSARY GOLD 4 SPEED AUTO
OLD - 2006 BF MK2 XR6 BIONIC 4 SPEED AUTO[
OLD - 2007 BF MK2 XR6T SILHOUETTE 6 SPEED MANUAL
CURRENT - 2009 FG G6E BLUE 6 SPEED AUTO
alpineau is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 04:56 PM   #2
TwistedEL
TwistedEL's Avatar
How fast were you going? It will change regardless if you are going too fast for the selected gear.
Otherwise check the fluid level for starters
Old 07-01-2007, 05:07 PM   #3
HLC
Audi S3
i know the 6spd ZF's will stay in drive if they box gets too hot.
maybe the 4spd BTR's do the same? yeah check your fluid levels etc.
Old 07-01-2007, 05:13 PM   #4
alpineau
alpineau's Avatar
will go have a look now thanks for the quick reply's
Old 07-01-2007, 10:56 PM   #5
AU_Wagin
AU_Wagin's Avatar
It maybe just the inhibitor switch thingo, mine did the same, was fixed in 15 minutes at auto shop
Ray
AU_Wagin is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 11:25 PM   #6
alpineau
alpineau's Avatar
I have checked all the fluids and there fine i think i will have to take to an auto shop and get it looked at, i can't see it being a big problem because the auto is shifting fine it's only the manual selection that's not working
