Old 27-09-2006, 10:21 PM   #1
S3SR
S3SR's Avatar
Default steering shudder
when crusing at 100kish and hit the brakes semi-hard the wheel shakes so much im gonna crash.
any ideas....brake pads, rotors, idiot driver...?
also whats the easiest way to change leads? and can i go 10mm leads?
and plugs if i go to big can it damage my engine?
i ask that because im gonna change the lot rotors, pads, leads, plugs, secondary pod filter..hehe
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 10:41 PM   #2
DOC
DOC's Avatar
Brake shudder is common, you need to get your disks machined and posibbly some new pads
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 10:43 PM   #3
ReVd_uP
ReVd_uP's Avatar
brake shudder, either machine the rotors, if theyre still thick enough or repace them, as far as leads, i find its easy enough just to remove the intake snorkle to give you room to get to the coil pack then just swap em, shouldnt have a drama
ReVd_uP is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 11:38 PM   #4
GK
Walking with God
GK's Avatar
Get the front discs machined first, that should sort it out. It was the problem on my SR. $66 later and no shudders!
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 28-09-2006, 12:20 AM   #5
TwistedEL
TwistedEL's Avatar
Easiest way to change the leads is to take the airbox & snorkel out of the vehicle and just do one at a time
The hardest part about it is cutting the cable ties if it's the first time they are being done.
Old 28-09-2006, 01:26 AM   #6
JC
JC's Avatar
Brakes - as everyone has already said, get the discs machined, and new pads too.
Leads - yes, you can go 10mm, but there's really no need. I had more issue with the $#130 10mm spiral wound Top Guns on my 6, then with the original motorcrafts. Am running Topguns now, again, but just the standard 8mm ones and car runs great.
Plugs - Try the denso plugs from Toyota, they are the same as the ones ford supply, but about $10 per plug cheaper (around $15 compared to $25). Standard Denso part number is VW16R-A13 and the Denso Iridium is IW16. The only reason Ford use iridiums instead of copper cores etc, is that they last longer (around 100,000km instead fo 30 to 40,000km), so you can use either of the plugs. Or you could go Bosch, champion, NGK, motorcraft etc.
Ford Performance Club ACT
Old 28-09-2006, 10:27 AM   #7
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
You will need to get your discs machined, but most AU's do this to a certain point. Best bet is to get slotted rotars, which will just about completley eliminate brake shudder.
Good Luck
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2006, 11:59 AM   #8
S3SR
S3SR's Avatar
Good Luck
no of a rough price?
ive already ordered by plugs and leads... bosch FTW oh and a bosch coil pack too
then some DBA's slotted and x drilled....ill find out soon. and ferrodo pads?
also might replace all my radiator hoses, and new thermostat (depends how cheap they are).
also whats the approx going rate for 2nd extractors? and will they bolt straigh up to my existing system?
ill post some picies when i get the stuff in my workshop thread
thanks
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 28-09-2006, 12:16 PM   #9
Dauphin
Irregular member
Dauphin's Avatar
I had this when I first got my AU. Ford machined them for free as it was sold like that. There's a home business near my place that does each disc for about $80 I think.
Old 28-09-2006, 12:47 PM   #10
S3SR
S3SR's Avatar
good news i couldnt wait for autobarn to get them so i went to supercheap and.....wow supercheap is actually cheaper the autobarn. lol
some pics now in my workshop thread
My Cars:
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
Old 28-09-2006, 01:40 PM   #11
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
$80 for machining?
I had a place on the south coast that did it for $15 each as long as I supplied the disc (they didn't have to remove it)...
Old 28-09-2006, 01:44 PM   #12
Dauphin
Irregular member
Dauphin's Avatar
Wow, $15! That sounds amazing. This place also does it "on car," so maybe that's why?
Old 28-09-2006, 03:12 PM   #13
JC
JC's Avatar
Normal off car machining should be around $20 each, plus GST, and $30 for slotteds (extra cost is for them to resharpen the bit after the slotteds blunt it).
Old 28-09-2006, 08:24 PM   #14
GK
Walking with God
GK's Avatar
$66 for front slotteds @ Brakes Plus, was the standard price though, he reckoned slotteds are a little more (now I know why!) but gave me the standard price.
GK
Now gone!
On LPG
