Old 26-09-2006, 05:39 PM   #1
EFManual
Sully's XR8
Default changing standard dash to tickford dash in a au series 2
i have a problem trying to change my standard dash to a tickford dash. When installed the right indicator and the instrument lights don't work is this a common problem due to it not being compatable or is the dash faulty?
EFManual is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2006, 06:02 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Maybe try a search , i read a thread on this issue not long ago , and one of the members here gave a full listing of what wires need to be swapped around on the cluster plugs to get different series clusters to work in different series cars .
A few wires do need to be swapped around on the plug , the cluster isn't stuffed ;) .
gl
EDIT .......
Actually i think this was the thread http://www.fordforums.com.au/showthread.php?t=65477 cheers .
:eclipsee_
Old 27-09-2006, 10:36 AM   #3
sleeper
sleeper's Avatar
Default gauge works
gauge works in geelong ,vic can help you out they converted mine $80 . :
sleeper is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 04:33 PM   #4
EFManual
Sully's XR8
Default gauge works
i've rang gauge works in geelong and they don't want to touch it but thanks for the heads up any other suggestions
Old 27-09-2006, 05:32 PM   #5
S3SR
S3SR's Avatar
just dont indicate right and drive at night...lol
i know either here or aufalcon.com had a write up about the BEM/cluster things..
try searching for tickford cluster or high series cluster or high series BEM something in there might help
My Cars:
2002 Ford Falcon AU S3 SR
2006 BF MKI Falcon XR6
2008 Mazda BT50 SDX
2004 BA XR8 ute
2006 AUDI A4 B7
2013 FG II XR6 Ute
2006 Ford Territory TX
2003 Ford Falcon XR8
2009 Territory Turbo Ghia
Current: 2012 Audi A4 B8 2.0T Quattro
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 07:31 PM   #6
EFManual
Sully's XR8
does any one have a wiring diagram or which pins are for which on both clusters that would help alot
Old 27-09-2006, 07:47 PM   #7
Duffman
Oh Yeah!
Lg does.
Youd be surprised how easy it is. You only need to change a few wires over to the other side, I used little clip on things to make them hold onto the correct plugs rather then making a loom and works perfect also holds on strong too. Worth while mod but then you need to change your km's, I still havent done it and it still bugs me.
Oh no! Duffman can't breath! Oh, yeah!
Duffman is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2006, 11:28 PM   #8
LG
LG's Avatar
PM me, I've posted this before. Search on my name.
Old 29-09-2006, 12:10 AM   #9
EFManual
Sully's XR8
thanks heaps guys the dash works a treat as you can tell from my user name i'm new to the AU series
