25-09-2006, 08:15 PM | #1 | ||
Fairlane
Hi guys,
i remember seeing something about an easy fix for a rear shock rattle, but i can't find it again! can somebody send me a link or something, cheers __________________
Ford and Jeep.... both four letter words 2006 TS Territory AWD 2016 Everest Trend 4WD |
25-09-2006, 08:20 PM | #2 | ||
is this for IRS?
25-09-2006, 08:21 PM | #3 | |||
Fairlane
25-09-2006, 08:24 PM | #4 | ||
Hmm, got me then. Most of the issues with rattles in the rear are to do with IRS shocks punching through the top shock mounts. Live axles dont seem to have the same issue.
25-09-2006, 08:27 PM | #5 | ||
The bolts through the bottom mount of the shock need to be REALLY tight or they rattle, try doing them up as hard as you can. Had to do mine twice after lowering the car.
25-09-2006, 09:35 PM | #6 | ||
Would this 'rattle' sound like a bit of a knock? Could it be the same problem coming from the front of the car? Mine has a bit of a knock in the front when I go over a bump. I've checked out all the bushes, and they are all fine. I know the front suspension was recently all replaced just before I got the car. (My mechanic had a look, and told me it all looked new, then when I took it back to the yard to get the rear lower control arm bushes done, he told me he'd already done the front end suspension on it.)
After reading this thread, I'm thinking maybe the bolts in the struts may not be tight enough. Thoughts?
Some people think I suffer from A.D.D., but they... Oh LOOK! A Chicken! |
26-09-2006, 02:00 AM | #7 | |||
26-09-2006, 08:56 PM | #8 | ||
Fairlane
I will investigate and get back to you, thanks for the input!
28-09-2006, 06:50 PM | #9 | ||
After I put in XR coils in my Forte, it had an annoying knocking/clunking sound. I thought I had tightened up the shockies right. Even used a torque wrench. It only went away after I tighten the bottom shock bolts even further.
28-09-2006, 07:50 PM | #10 | ||
BA GT-P Owner
Just a thought...has anyone looked at there wheel bearings
Cheers Mark
DAILY DRIVER/TRACK CAR BUILD NUMBER 006 299.5 rwkw's 12.74 @108mph ON MT's ON MAXXIS MAV1's 275/45/17 13.27 @ 106mph
28-09-2006, 09:54 PM | #11 | ||
ive got the same problem with my xf rattles in rear end, wheel bearings ok ,all bushes ok but i found the inner disc brake pads rattling around thats all i could think what it would be but now im going to tighten my shocks after reading this thread as there is more than 1 rattle its only happened since i changed my diff
