Old 25-09-2006, 07:40 AM   #1
james22
With da Warlords
james22's Avatar
Default Changed Cam on Weekend
Well there we are.
Friday night, I decided spur of the moment style I was going to change my cam.
Later that night I had my spare xr6 engine apart with the cam in my hands : .
Saturday morning I chucked her in my car. I have to say when I first swapped them over I was dissapointed at how it ran. It actually seemed slower, but the computer has not realised what I have done and so it would seem that theres a lot more power to come. As I've been drving over the weekend it has started to get a little more responsive & better idle as the computer adjusts.
I just cant wait for the flash tuner to turn up this week, that should really open her up.
All up the job took me about 8 hours, and for anyone that hasn't done it before, believe me it's not that big a job to do. I found the worst part was removing the power steering pump and putting it back on so that I could get to the chain tensioner.
Anyway thats was my weekend, a bit dissapointing but seems to be improving now with every km :
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 25-09-2006, 08:16 AM   #2
jonbays
TL40 Wagon?
XR6 Cam alone won't do much. The XR6 needed the head cam and ecu to get the extra power. You'll be waiting a long time for the computer to adjust to give you more power to so give up on that idea and get the flash tuner for sure. The ecu won't be doing any adjusting just cause you swapped the cam. It will only be going through its idle train and trims if you disconnected the battery. Now a flash tuner will get the best from this set up.
Good luck and let us know how it all goes with the tune
Old 25-09-2006, 06:59 PM   #3
Baboon_AU
Baboon_AU's Avatar
good on you mate.. i also got a different cam on the weekend butit took me an hour to do my cam, not 8
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2006, 07:08 AM   #4
james22
With da Warlords
james22's Avatar
Most of that time involved pulling power steer off & putting back on, and disassemble spare engine. Once that was done it was easy. Do you like the grind you've got in your car now?
My computer is only now realising that air fuel ratio should be 14:7, used half a tank of ultimate in 100km.
Windsor Warlords
AU III XR-8220
Old 26-09-2006, 05:54 PM   #5
EvilChief
Boost Addict
14:7?
14:1 is about right for a factory tune, and yes it takes the ecu a little while to adjust for a new high lift cam
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 26-09-2006, 07:05 PM   #6
Baboon_AU
Baboon_AU's Avatar
yes i am happy with my cam
