Old 16-09-2006, 10:47 PM   #1
AU3 HERROD XR8
XR8 M8
AU3 HERROD XR8's Avatar
Default subwoofer on rear shelf.. or in the boot?
Hey guys, I just wanted to ask that i relised under my parcel shelf in the centre there an extra whole, I'm guessing its for a sub. Now would I be better off cutting a hole in my rear shelf which I'm not quite open to considering it's a nice looking shelf:P lol and fitting a sub in there, or should I just go ahead with installing a seperate one inside the boot and maybe throw in an amp or two etc etc
cheers
The King of the jungle doesn't whistle.. he roars!
AU3 HERROD XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2006, 11:11 PM   #2
jimt3te50
My kids think I'm cool
jimt3te50's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Jim has consistently for some time now shared his life, and his passions in his XY GT and more so his FG GT in a way so everyone here feels part of the journey, which helps make AFF such a worthwhile place to be.  An outstanding contributor in my book.
depends how far you want to go- don't cut the shelf as you don't need to.
Fit a basic 8" sub in the shelf from the top (you can even fit it (or a 10") from the bottom if you're too lazy to take the trim off the top of the shelf) but it will just sound ordinary at best....... too many rattles and there's lettle you can do to fix it.
I was told this and was adamant I could to prove everyone wrong and I failed. Bought a great 8" RF Punch sub and tried everything to make it work, but separate box in the boot is best bet by a country mile
2011 FPV GT 335 >My Build Thread<
(Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page)
BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable...
2018 Ford Ranger RAPTOR
2013 Audi SQ5
jimt3te50 is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2006, 11:12 PM   #3
Whoosha
AU DIE HARD
Whoosha's Avatar
that hole is for the factory sub.. cutting holes in parcel shelfs is a big no no with insurance companys so put them in the boot be hind the seats then box the rear across
Originally Posted by Riksta
Old 16-09-2006, 11:18 PM   #4
AU3 HERROD XR8
XR8 M8
OK then looks like im keeping the shelf i was never pretty warm with the idea of cutting a hole in my shelf, and was told by a mate like you said also too many rattles etc. I was hoping i could get the sub in there for satisfying sound and still make it look clean and mean without having a big box laying in the boot etc. I don't want to go over board and make it a competition sound system but like i said, something satisfying..
All opinions and ideas welcome
Old 17-09-2006, 12:24 AM   #5
JC
JC's Avatar
Try screwing the sub into the middle part of the backrest, facing forward. It's out of the way then, and you will still get the sound, without the metallic rattles, through to the cabin.
There's a good reason for not cutting the parcel shelf - it's a structural part of the car, so cutting it would weaken it. It's not like older cars where the parcel shelf was a bit of MDF that could be replaced at will.
Ford Performance Club ACT
Old 17-09-2006, 09:35 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
heres one we prepared earlyer .... was reasonable cheap & easy to do .a bit of chip board .carpet .& 3 hours later . the only down side is you loose your rear seat access to the boot
Old 17-09-2006, 10:13 AM   #7
xr8man83
Grunt Files
xr8man83's Avatar
go the boot you can make a good box and have grat sound cutting the parcel shelf aint a good idea but do some homework on the box cause they have to be spot on for the best sound and it all depends if you want boom boom or a bit of s.q on how you design the box
xr8man83 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 12:04 PM   #8
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
So true ! , also the type of wood used for the box / and the length and size of the port ( if you add one ) makes a big difference too ( i know this for a fact from experiance making and using quad boxes over the years for electric guitars ) .... chipboard is crap ! - it absorbes alot of the bass/bottom end and you loose alot of the punch , 12 to15mm (or thicker) mdf has been proven to produce the best base/ bottom end .
:eclipsee_
Old 17-09-2006, 12:27 PM   #9
AU3 HERROD XR8
XR8 M8
OK, thanks for the ideas guys, looks like i'm going for the boot then. Just a matter of planning and getting everything ready now
cheers.
Old 17-09-2006, 01:08 PM   #10
AU3 HERROD XR8
XR8 M8
how does something like this look..??
plus i still get to keep my boot access from the rear seats:P
Old 17-09-2006, 01:27 PM   #11
JC
JC's Avatar
Looks great to me - but expensive. Just throw an 8" in the parcel shelf and see what you think. When I had mine, it was certainly nothing great, but was better than not having one there. Now with the gas tank in the way, I have no choice but to not have one in the parcel shelf. One day I'll get around to fitting it to the back of the back seat.
Old 17-09-2006, 01:35 PM   #12
duaned
duaned's Avatar
For sure in the boot will certainly provide better bass response than the parcel shelf. Here's a pic of mine...
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 01:40 PM   #13
AU3 HERROD XR8
XR8 M8
true it's better than not having it at all, but then again i think i should just save up a little more and try and do something with the boot, loll i love my rear shelff too much to see it cut:P plus like you said cutting it would just weaken then shelf.
Old 17-09-2006, 01:42 PM   #14
AU3 HERROD XR8
XR8 M8
that looks great! mate i love how you made the boot look so clean with the carpet etc i want somethign like that
Old 17-09-2006, 01:49 PM   #15
Hords
Treasure your balls?
Hords's Avatar
Any difference to SQ with the sub facing rearwards? Most I've seen point towards the front of the cabin.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 01:56 PM   #16
JC
JC's Avatar
An 8" fits with no cutting required. But it depends on whether you REALLY want lots of bass, or like me, you just wanted more than the crappy factory speakers can provide. I certainly didn't want the doof, doof effect, so the parcel shelf one suited my purposes.
Old 17-09-2006, 02:07 PM   #17
AU3 HERROD XR8
XR8 M8
i'm not really after the doof doof stuff lol but just something above average, maybe an 8" is the answer, keep in mind i still want my boot as clean as possible so i think at this stage i'm going to either use the 8" or do something like the pics i posted earlier (but more simpler) and theres also the choice of leaving the sub and getting high quality speakers.... hmmm very tough choice
Old 17-09-2006, 07:34 PM   #18
HLC
Audi S3
how about this set up? :hihi:
fully sick, uleh?
Old 17-09-2006, 08:53 PM   #19
AU3 HERROD XR8
XR8 M8
fully sick, uleh?
mate.......WHAT HAPPENED TO IT, lol you're giving me second thoughts about even touching my boot now used:
Old 17-09-2006, 08:53 PM   #20
AU3 HERROD XR8
XR8 M8
haha don't tell me thats your boot HLC lol
Old 17-09-2006, 09:00 PM   #21
HLC
Audi S3
that is totally my boot. except now its full of 5hit and it doesnt have the sub in it : the rubber has pretty much all fallen out/perished so my free speaker is dead. still got the box.
am looking to sell it as i dont want a 12" sub. its perspex. and SOLID (in structure- its at least 15mm perspex all around- might be 20, i forget). will consider any reasonable offers.
Old 17-09-2006, 09:35 PM   #22
ClassicAU
seriously, how often do you have to fold down the back seats anyway! i just booked my car in to get a custom boot install. i say go a good 10" in a box in the boot.
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 10:31 PM   #23
duaned
duaned's Avatar
Rear loading seems to be more popular these days. You get the effect of rear loading which increases bass output in the cabin of the car. But you should experiment at which method you prefer.
