Old 26-08-2006, 01:56 PM   #1
ronwest
All Bran = Regular Member
Default Is this a Camber Kit??
This kit was sold to me as an AU camber kit. I bought the fr and rear but for the life of me I can't see where it fits (AU3 Fairmont Ghia) .
Can someone confirm whether this is an AU camber kit (one side)?
If it is, can you also tell me how to fit it?
Thanks...
Old 26-08-2006, 02:02 PM   #2
bodes-sh
no it's not, thats a sway bar link...whoever sold it to you has some explaining to do...
Old 26-08-2006, 02:04 PM   #3
ronwest
Thanks mate... at least I'm not as dull as I was beginning to think.
Sold by Ford spare parts... go figure...
Old 26-08-2006, 02:07 PM   #4
ronwest
Does anyone have a pic of a camber kit - on or off the car would do.
Obviously "c.a.m.b.e.r. k.i.t" doesn't mean too much to my local Ford guys.
Old 26-08-2006, 02:09 PM   #5
bodes-sh
here is a pic...its not a ford one but they all look the same
Old 26-08-2006, 02:14 PM   #6
ronwest
thanks again....
yeah that makes a bit more sense.
Just tried to ring my local Ford dealer.
No answer on parts line and no answer on main number. At 2pm on Sat arvo.
I betchya my local Holden dealer will at least answer the phone <sigh>
Old 26-08-2006, 02:17 PM   #7
bodes-sh
good old ford spare parts at it again...they probably close at 12 noon lol
Old 26-08-2006, 02:39 PM   #8
jossa
Best AU body kit - NONE
Bodes sh is correct, that is a sway bar link kit. (every commodore VN - VZ will need these replaced at least once!) Go into Repco or Bursons and they will have a Nolathane, Kmac or Noltec version with bolts, mount and bushes. If your camber needs a kit for that much adjustment, check your upper ball joints too.
jossa is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 02:55 PM   #9
ronwest
Actually I fitted XR suspension to my Ghia.
Same Ford crew told me that I wouldn't need the camber kit with the XR suspension...bzzzt...wrong...
Oh well, I'm learning a bit about my AU.
(I'm also learning a bit about my local Ford dealership)
Old 26-08-2006, 03:10 PM   #10
blackers10
blackers10's Avatar
i have a fulcrum camber kit
its got long bolts for hte upper inner control arm mounts and new brackets etc for it
and a few different packets of shims
Old 26-08-2006, 03:33 PM   #11
buickman
buickman
buickman's Avatar
Is the kit for the IRS or the front?
Hey some people are good salesmen but a lot have no idea even looking in books or the computer for a part.
Old 26-08-2006, 03:39 PM   #12
blackers10
blackers10's Avatar
its definatly a front swaybar pin
the silver things go on each side of the bushes like the bread of a sandwich
id know because i undid mine the other day
the AU only needs a FRONT camber kit and thats all that you can buy from anywhere from what ive researched (as i originally thought you needed a REAR item like the commodores..)
Old 26-08-2006, 03:51 PM   #13
FTE217
T3/Sprint8
FTE217's Avatar
Get the camber kit which works from the upper control arms, has heaps of shims for the aligner to use,best ones on the market if used by a good operator.
Pedders,nolathane or superpro have the better product.
Forget the lower bolt adjusters like the pic shown by bodes-sh.
Those link pin kits are for the earlier Eseries Fords.
Commy link pins kits are replaced more than once in their lives believe me....
Rear camber kits are unneccessary for the AUIRS, great design compared to the Commy which sits negative all the time and worse with more weight in the boot or passengers, 18-19+"rims in these cars wear out rear rubber under 20000clicks if soft compound like in HSV's.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 06:51 PM   #14
buickman
buickman
buickman's Avatar
QUOTE=blackers10]its definatly a front swaybar pin
If the AU has IRS & not a XR & has XR or lowered springs to have it aligned correct you need 2 P/N 5K500ART upper arm camber service kits for the IRS
Old 26-08-2006, 06:55 PM   #15
ronwest
Thanks for the part number, buickman.
Yes, that is the situation with my car.
You got a p/n for the front kit?
Old 26-08-2006, 06:59 PM   #16
ronwest
I ordered and paid for 2 x front and 2 x rear kits.
To be honest, I didn't look that closely when I picked them up.
Came to $96 for the 4 items which is around what I'd been told the camber kits would cost.
I assumed (yes, I know) that the parts were correct...
Old 26-08-2006, 07:05 PM   #17
bodes-sh
as i said
they are for an accent/lancer/small jap type car NOT A FORD
Old 26-08-2006, 07:07 PM   #18
buickman
buickman
buickman's Avatar
The AU ghia that I had was fitted with Kings SL springs & the front end guy was able to align the front with shimms as he had problems in the past of the rachet kits moving if hard bumps were encounted on some cars that he had fitted the kits to I had no tyre wear problems with the XR IRS camber kits in the IRS & the front shimmed.
Old 26-08-2006, 07:14 PM   #19
philstoj
philstoj's Avatar
Click the link, and look at the top left hand corner of the pic with all the bushes, thats the ones you need.
The other pic posted earlier is of a kit to suit strut front end, and they dont look all the same.
click --> http://www.redranger.com.au/docs/ali...correction.htm
Old 26-08-2006, 07:38 PM   #20
philstoj
philstoj's Avatar
Heres a set for sale on ebay.
http://cgi.ebay.com.au/Camber-Caster...QQcmdZViewItem
Old 26-08-2006, 09:39 PM   #21
Baboon_AU
Baboon_AU's Avatar
and camber kits don't nessicarily need to be fitted to both sides.. i just addes a few shims to my left hand side that my neighbour gave me and then his mate did a wheel alignment for me and its sweet as. drives perfectly straight,
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 10:01 PM   #22
blackers10
blackers10's Avatar
how much should the XR IRS bolts cost?
does pedders or any other company do the appropriate part for this also?
im on SL kings
Old 26-08-2006, 11:17 PM   #23
Abacus
Life's a Gas
Abacus's Avatar
im on SL kings
I paid about $38 for each side from Ford.
Abacus is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2006, 11:45 PM   #24
blackers10
blackers10's Avatar
cheers mate
Old 27-08-2006, 10:06 AM   #25
buickman
buickman
buickman's Avatar
im on SL kings
Unfortunally Ford are the only 1's that have them but you can get pedders to get them for you from Ford at a cost.
I only come about knowing that a camber kit existed for the IRS after fitting a set of tyres from Bob Jane after lowering & the inner tread was wearing on the back. I went back & the guy could not work out why there was no adj on the camber. So went to another front end guy that does ralley cars & he said there is no camber adj bolts on the car so then a trip to Ford & found out that only the XR's with IRS had the camber kits the others had just a bolt & nut only.
Old 27-08-2006, 12:08 PM   #26
blackers10
blackers10's Avatar
aaa ok thanks for that buickman
Old 27-08-2006, 01:52 PM   #27
GK
Walking with God
GK's Avatar
I have Xr Springs on the SR Sedan, but only 16 inch tyres. I didn't think therefore that I needed a camber kit.
I thought that it only gets to be a problem for alloys 17inch and over. Can anyone confirm this?
In any case, I'm getting new tyres next weekend from Bob Jane, they'll let me know, like they did when I ran out of adjustment on a Laser that I had which had some prior accident damage.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 27-08-2006, 02:40 PM   #28
ronwest
I thought that it only gets to be a problem for alloys 17inch and over. Can anyone confirm this? GK
I've got 16's on my Ghia. I'm not sure whether to go to 17's as we do a fair bit of country driving and I don't want to compromise the ride comfort any more than I have to. I also like the design of my 16's
I was told by my local Ford that I would not need the camber kit after fitting XR springs.
After about a thousand k's my tyres got noisy and are just starting to feather.
There is no doubt that on mine at least, it needs the camber kit.
I'm just a little confused after comments in this thread whether I need front and rear, or just rear.
I'll probably get both and let the wheel aligner sort out what's what.
Old 27-08-2006, 02:42 PM   #29
blackers10
blackers10's Avatar
the 17s wont be as floaty on the road and through corners
Old 27-08-2006, 03:59 PM   #30
XR6Stu
Its sad alot of people seem to find out about their local Ford dealership in this manner!
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
