Old 24-08-2006, 10:51 AM   #1
superroo
You can't stop the signal
superroo's Avatar
Default heat proof liner (hood liner)
My question is, are the heat proof liners necessary.
Cause on my car i've got one along the firewall, that's torn and generally worn. What are the effects if i remove this?? Will i notice more heat in the cabin? or will it discolour the paint? Advisable or not
Also what about the hood liner? necessary or not??
Old 24-08-2006, 12:57 PM   #2
blackers10
blackers10's Avatar
lots more heat in the cabin.
Old 24-08-2006, 01:05 PM   #3
EA2BA
PM me if you want
EA2BA's Avatar
the firewall lining, you will notice heat and more noise fromthe engine bay
Bonnet lining, you will notice more engine noise, and most people say the extra heat it stops will fade the bonnet paint.
Old 24-08-2006, 06:08 PM   #4
Mechan1k
Mechan1k's Avatar
Definitely will fade the bonnet if you remove the bonnet liner. It will take some time to do ... but much quicker without the lining in place.
Old 24-08-2006, 06:30 PM   #5
GK
Walking with God
GK's Avatar
I've wondered about one from time to time on the S1. I wonder how much they are worth from FTG, they're bound to have oooodles of them!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 24-08-2006, 07:00 PM   #6
Baboon_AU
Baboon_AU's Avatar
when the lining is all torn and worn and the firewall and you are working near it and you rub against it with your arm you get a real itchy arm and u will spend all night picking fiberglass like splinters from your arm..this happened to me when i was shimming my wishbones
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2006, 07:08 PM   #7
39ClevoUte
39ClevoUte's Avatar
Does nothing.... Ford spend millions of dollars employing 200k a year engineers to find noise and heat reduction and from what I here thay make up all this S@@@T to keep themselves in a job. I'd have no hesitation in removing it.
39ClevoUte is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2006, 11:18 PM   #8
Sleeperau
Highway Taxi
GK
I was quoted $85 from a wreckers in Brisbane, damm intake rubbing!
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 06:35 AM   #9
AU-MUSTD
Flat floor shifter
AU-MUSTD's Avatar
Remoned my hood lining over a year ago and all is fine.
AU-MUSTD is offline   Reply With Quote Multi-Quote with this Post
Old 30-08-2006, 07:25 AM   #10
Casper
Contributing Member
Casper's Avatar
Same.. made zero difference
Older, wiser, poorer.
Old 30-08-2006, 08:04 AM   #11
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
U'll find most people who have a shaker on their car ( i did on my old XE ) have had no problems at all without the bonnet/hood lining, it made ziltch difference.
As far as the firewall lining goes , i personally wouldn't remove it just for safety sake of keeping the electrics behind the dash cooler. Also if you had an engine bay fire , that fibreglass lining would also probably help the firewall stay a little cooler , also saving the risk of fryed/burned stuff behind the firewall in the cabin behind the dash.
cheers.
:eclipsee_
Old 30-08-2006, 05:08 PM   #12
LOWAU
___________
LOWAU's Avatar
I have a S1 AU falcon that doesn't have the hood lining and the firewall lining. There is no extra heat that I can feel in the cabin but there is extra nosie which I quite like as you can actually hear the extractors and engine work.
As for the paint fade, this is bull as the car is almost 8 years old and there is no paint fade.
LOWAU is offline   Reply With Quote Multi-Quote with this Post
