Old 29-05-2006, 03:42 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Stall converter
Just a quick question to quell my curiosity...
If I put a 2500rpm stall converter in my ute, what would need to change electronically for it to work properly?
Would a retune of the car also be required?
Carless
Old 29-05-2006, 03:48 PM   #2
adxr8
Rebuilding the ED
adxr8's Avatar
Default Stally
Hi Kenny, electronically nothing needs to be changed. I put one in my EB and didnt change anything. Talk to the guys at Brisbane converter exchange they have learnt lots more since they done my first one and are currently doing me another without the lockup installed. The only trouble im having is it wont change into 4th after a big burnout, have to get the temp solenoid removed or adjusted.
Adam
ED XR8 In for a rebuild
347 Dart block:All the Scat goodies, Edelbrock Victor Jnr's, Trickflow manifold and Vortech on the stand/ work in progress
adxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2006, 03:52 PM   #3
TheSneakiness
Adapt or perish...
Adam
Thanks Adam.
I'll more than likely be dealing with Ron Hill Automatics up here, they have a good reputation and do a good job.
Then I can get them to do a dyno run too... :
Carless
Old 29-05-2006, 03:57 PM   #4
adxr8
Rebuilding the ED
adxr8's Avatar
They probably get there converters from Brisbane, they send there stally's all over the country.
Old 29-05-2006, 08:14 PM   #5
Free347
No tunes or other changes at all - just stick it in and plant your foot!
Free347 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2006, 10:19 PM   #6
Mechan1k
Mechan1k's Avatar
Not suited for towing of heavy load carrying though ... if using the ute for work I'd suggest not getting a high stall.
Old 29-05-2006, 10:21 PM   #7
Fairlane
V8 Powaah
Fairlane's Avatar
Cant help you with the stally question, ive used Ron Hill Automatics (Maroochydoore) for service work on my old El (Diff and Auto), they do a good job, but they arent cheap.
FG G6E Turbo- Seduce & Cashmere - Sold
XF S pack Sedan- AU 302 Windsor, T5, 2.77 LSD, Many Mods
Fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2006, 09:03 AM   #8
TheSneakiness
Adapt or perish...
That's where I can get away with that.
My ute doesn't carry loads all that often. Maybe twice a year.
Yeah, I knew that too. They do some great work, but be prepared to pay an arm and a leg for it.
Carless
Old 30-05-2006, 12:17 PM   #9
blackers10
blackers10's Avatar
burpengary transmissions seem to have a GREAT reputation
i dunno about stallconverters thru them tho(never been looking for them)
Old 01-06-2006, 12:27 PM   #10
TUF514
do they increase power putting in a higher stall?
TUF514 is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2006, 01:30 PM   #11
Racecraft
they call me Tibbo
Racecraft's Avatar
nope, just match forward motion to the powerband..
Alot better acceleration..
Old 01-06-2006, 05:37 PM   #12
Casper
Contributing Member
Casper's Avatar
Thet actually will reduce rwkw usually as they are more prone to "slip", even at WOT. Most aftermarket histalls will not lock up fully (in fact most Ford factory converters dont lock up fully). The higher the stall ,the more prone to slip, the lower the rwkw... but damn doesnt the launch make up for it
Older, wiser, poorer.
Old 01-06-2006, 09:08 PM   #13
duaned
duaned's Avatar
sob sob!..... tell me about it Casper! :evil_laug
duaned is offline   Reply With Quote Multi-Quote with this Post
