19-05-2006, 02:57 PM | #1 | ||
Tickford Rules!
Hi guys,
Have noticed in the last couple of weeks that when I start my XR8 after it has been standing for a few days, that just after the engine fires, there's momentary metallic sounding rattle coming from the engine. It goes away after a second, and doesn't return on additional start-ups when the car is warm. Also, if I start the car the two days in a row (i.e when it just sits overnight), the rattle is much more quiet, or not really noticeable. Any thoughts? All comments/suggestions appreciated HP Dude.
Tickford Rules! :eclipsee_ 1969 Ford Fairmont XW 1999 AU I Falcon XR6HP 1999 AU I Falcon XR8 (sold) 2007 Mitsubishi Evolution IX 2009 Lotus Elise S |
19-05-2006, 04:07 PM | #2 | ||
335 kw of goodness
There is a thread about this very thing. But I will anwser you anyway.
Give your XR an oil & filter change, use a 10/40 oil [non synthetic] Helix plus 10/40 is what I use in my TE50 I sure that will fix the rattle at startup. Change your oil every 8 to 10,000Ks..
CAUTION! STILL Contain's opinion's & fact's that may offend !!! : 2012 GTP 213 black what was I thinking? NOW FOR SALE>> http://www.fordforums.com.au/showthread.php?t=11439680 |
19-05-2006, 04:44 PM | #3 | |||
Tickford Rules!
I did a search but couldn't find that thread. Sorry for the repost.
19-05-2006, 05:44 PM | #4 | |||
Sounds silly I know but start it cold and while you hear the rattle spray or throw some water on the idler pulleys and belt, noise will go if culprit. If its a rattle more than a knock then this can sometimes be the culprit and new idlers are cheap as chips. Found that to be the problem also on sons EF XR8. |
19-05-2006, 06:13 PM | #5 | |||
Tickford Rules!
19-05-2006, 10:26 PM | #6 | ||
Muzza had a rattle at startup - only when cold. Replaced his battery and no more noise/rattle. Turns out the old battery was probably not supplying enough power to the starter to retract the little cog from the flywheel, which was causing the rattle. At least that's our theory, anyway.
19-05-2006, 10:34 PM | #7 | ||
what are all these strange answers, everyone knows that in cold weather the oil goes thick when cold and has drained to the sump and takes a while to get pumped up to the rockers. that's all there is to it
20-05-2006, 01:08 AM | #8 | ||
Tickford Rules!
Thanks guys, appreciate all input. The battery is an interesting suggestion, as it was recently flat due to the car being under used. Might change the battery in the course of servicing.
EBFalc's suggestion also makes perfect sense as it occurs when the car stands for days on end without being started, although we have other cars that are rarely driven, and I don't recall them making the same rattle on start-up. Anyway, as long as it is not symptomatic of a more serious (read expensive) problem, then I'm happy!
20-05-2006, 01:23 AM | #9 | ||
My kids think I'm cool
Hypeurtectic pistons can rattle on start up too, until they come up to temperature and expand......
Probably not it, but they do
2011 FPV GT 335 >My Build Thread< (Posts 3511-3515 has a compilation of most of the pics, page 118 @ 30 posts per page) BLUESTREAK built 5.2L flat-plane-crank VOODOO with 3.2L Intercooled Kenne Bell blower, 1000rwhp/746rwkw @ 8000rpm @ 20psi on E85. Built ZF with BLUESTREAK 2C Circle D converter. Unbloodybelievable... 2018 Ford Ranger RAPTOR 2013 Audi SQ5 |
20-05-2006, 11:22 AM | #10 | ||
Falcon Unbelievable!
I had a very similar noise a metallic type rattle on start up only when cold, turned out to be the exhaust touching the sump.
20-05-2006, 06:15 PM | #11 | ||
Dunnydore Destroyer
My AU Fairmont V8 has had this sound for 4 years and 100000 kms
Tried all types of filters and oils with no difference whatsoever I don't think its a flat battery ive replaced 2 in that time but the pulley and belt thing that howesy talks about could be it |
21-05-2006, 04:57 PM | #12 | |||
Walking with God
GK
