Old 04-01-2006, 10:32 PM   #1
albanycobra
albanycobra's Avatar
Default AU manual conversion
I know this topic keeps coming up and I've done searches.
But What i would like to know is- Can you convert a
series 1 automatic Au falcon to manual using an E series manual from say like a EA falcon? If so can you point me to someone who has succesfully carried
it out.
Thanks
albanycobra is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 11:17 PM   #2
couz^man
couz^man's Avatar
it out.
Thanks
Ditto to wat he said but series 2
couz^man is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2006, 12:30 AM   #3
LG
LG's Avatar
I only know of one person that has put a EA T5 into his AU. Not sure what he did. He is on fordforums.com. He is actually selling it, for about 800 i think.
You need some modifications for a V8 T5, to be put up to a I6. Things like the bell housing and input shaft.
The EA T5's and older, were weaker then the newer T5s. It'd be best to find the same model gearbox.
I found a guy in Victoria, that has a T5 for an AU, for about $900ish i think.
I found one full conversion in NSW, for $1900.
A full conversion, is likely to set you back about $1000-2500 + labour.
And that $2000 will cover, everything, new clutch, clutch cable, gear boot, gear knob, pedals.. All that jazz.
Old 05-01-2006, 09:50 AM   #4
couz^man
couz^man's Avatar
temping but the price aint LOL
Old 06-01-2006, 11:11 AM   #5
LG
LG's Avatar
Found an AU XR6 T5, that has done 5000 kms for $1200 in VIC. No bell housing or other parts (I dont think). 0417289663
The other AU XR6 T5, comes with clutch plate, flywheel, wiring, cable, $950ono in VIC. 0413076756
IT's Performance in NSW, could track the rest of the parts you need. Also eBay, and some other sources, you could organize all your parts for it. Just takes money and time.
Old 06-01-2006, 12:09 PM   #6
Bobman
Regulator
Bobman's Avatar
Do you need to change the AU ECU aswell?
Pedal Box would be the next harder thing to find...
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 12:20 PM   #7
LG
LG's Avatar
The AU's can be done like the EF/EL's. You can re-solder two parts of the ECU. Otherwise you will need a new "Manual" ECU. And get it re-programmed to suit your car. As your car won't start if you just chuck it in.
As for the Pedals, you can get the Mal Wood Clutch Pin Adapter for $100 or so. To add on to your Auto Pedal Box. Or track down a whole new manual pedal box.
Old 06-01-2006, 01:08 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
My conversion has been put on hold due to not being able to get a RIP shifter until mid January. As soon as BA CompanyCAr gets some stock I ready to rock and roll
Old 06-01-2006, 01:15 PM   #9
LG
LG's Avatar
About that ECU again. Did you get your Falcon ECU, flashed to the same as an XR6 Manual. Or did you get a XR6 Manual ECU and programmed for your Falcon?
And also, the Center Console. Are they different? Do you need a manual one?
Old 06-01-2006, 01:30 PM   #10
Racecraft
they call me Tibbo
Racecraft's Avatar
Manual ECU flashed to my BEM and key is the plan
I have looked at the consoles and although I think the opening is the same the manual console has the gear stick boot folded and attached to the underside of the console.. I gave the boot a quick wiggle and it seems to be glued on. For that reason I am just going to swap the whole console
Old 06-01-2006, 08:49 PM   #11
EvilChief
Boost Addict
center consoles are identical between man and auto, they are not cgluen on, just clipped in, they can be quite tought to get out for the first time
as for the ECU: eitehr way is possible
LG: u got urself a bargain GB u bastard :p i paid 2g a year ago
now i gotta find crossmember for myself again :S
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 06-01-2006, 09:32 PM   #12
Damo
The bottom bellhousing bolts won't line up if you use an EA bellhousing. sphell on the forums put an AU engine in his EA using an EA t5 and bellhousing and it all worked fine.
Old 06-01-2006, 11:38 PM   #13
albanycobra
Cool, So the gearbox bolts up?
Do you use the EA flywheel and clutch?
Do you use the EA tailshaft(manual) or the AU tailshaft (auto)?
When you say solder 2 parts of the ecu are you talking about the
inhibitor switch?
I am hoping to put an end to this mystery soon and document a conversion.
I was hoping someone who had done this conversion would pop up.
Au Falcon
DRB GT40 #64
Old 07-01-2006, 12:00 AM   #14
LG
LG's Avatar
Love you to.. :P
So, could i just get my Forte Auto ECU, re-flashed/programmed to say a XR6 Manual, or a Falcon S Manual.
If you were to get a XR6 ECU would you need the XR fuel rail, for the fuel rising regulator?
By the way, Chief still has his 14 second Engine if anyone wants.
Old 07-01-2006, 12:02 AM   #15
EvilChief
Boost Addict
ea flywheel and clutch will do, just double check input spline count,
as for length of the transmission, the selector part of the e series manual is not long enough to reach the AU hohle, sou will have to use an AU selector. converting that can be a pain
as for soldering yes the inhabitor switch
as for documenting conversion ... i always forget to do it when i am at it ...
N12 Pulsar - sold
Old 08-01-2006, 12:13 PM   #16
albanycobra
Do you mean the shifter stick is to short to come through the hole
or the gearbox is not long enough to line the shifter up with the hole?
If the gearbox is to short, Do you know approx how far out?
Au Falcon
DRB GT40 #64
Old 09-01-2006, 12:23 AM   #17
EvilChief
Boost Addict
as in gbox is not long enough ... i never tried it, but i have been told its about two inches too short
N12 Pulsar - sold
Old 09-01-2006, 10:23 PM   #18
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Hey guys couldn't find any other threads that looked to suit so i thought i would ask here is a conversion from Auto to manual on a AUII XR8 an expensive job looking for an estimate price and a good workshop in melbourne to do the job
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 10:32 PM   #19
LG
LG's Avatar
You can find a Gear box for $2000 from FTG AS.
Or I know of a guy that has two AU V8 T-5's for $1950.
And I know of another through my work that has a AU V8 T-5 for $1200. I think he may have sold it though.
I think you'll need to track down the rest of the parts to do the conversion though. Which are more or less easy to find.
I.E.
- Gear knob
- Pedal Box
- ECU (If you wish)
- etc
As for a place, my mechanic will be doing my conversion on mine, and can do yours as well. NE Suburbs of Melbourne.
Old 09-01-2006, 10:33 PM   #20
Racecraft
they call me Tibbo
Racecraft's Avatar
spigot bearing and a clutch cable
Old 09-01-2006, 10:43 PM   #21
FPV8U
FPV8U's Avatar
Thanks for the quick replys guys, had been given a price by a family member that seemed way, way too low and as it turns out it was, will hand the prices to the olds and see what they think.
Old 09-01-2006, 10:47 PM   #22
FPV8U
FPV8U's Avatar
Is the diff ratio the same for a Auto XR8 as it is for a Manual?
Old 09-01-2006, 10:49 PM   #23
LG
LG's Avatar
Actually that $2000 from FTG AS, also included shipping to WA. So it might be like $1850, $1900.
Heres some numbers:
AU XR8 T-5 (5 Speed) Gearboxes Complete x 2 $1950/ea
Auto Core Aust.
Ph: 5625-2634
Mob: 0418-863-892
My mechanic, is a Repco Service Dealer, so is experienced. So if you'd like to look into it. Let me know.
Old 11-01-2006, 10:36 AM   #24
FPV8U
FPV8U's Avatar
Heres some numbers:
Auto Core Aust.
Ph: 5625-2634
Mob: 0418-863-892
Thanks alot LG, could you give me an Estimate Total cost after parts and fitment if you know?
would i be looking at much over say $3,500?
Old 11-01-2006, 11:03 AM   #25
LG
LG's Avatar
As good as i can tell:
Clutch: $300
Cable: $50 (Ford)
Clutch Pedal: $100 (Mal Wood)
(or Manual Pedal Box: ~$150)
Gear Knob: $80
Gear Boot: $40
Re-Solder Existing ECU: $100 (Auto-Elec)
(or ECU: $350)
Pressure & Friction Plate: ~$500 (Repco)
Rubber Pedals: ~$50
(or Alloy Pedals: ~$120)
Starter Motor: ~$150
Fitting: ~$500
So all up, your looking around: ~$1900, for the rest of the parts, and fitting.
But these gearboxes for sale, could come with a few of the parts. (I don't know, because I havent enquired).
And then on top of that price, you got short throw shifter, shortened gear lever, oil, and whatever else you want.
So worst case, your looking at $3500-4000. But then you have all new parts. If you source some used ones, you could probably come out cheaper. Then you can sell some gear to re-coup some of the costs. Auto + Tranny Cooler (if you have one) + Gear Knob + ECU (if you replace it).
Old 11-01-2006, 11:07 AM   #26
LG
LG's Avatar
Diff Ratio is the same. 3.45:1.
For AUII XR8 Ute anyway. Should be the same for AUIII too.
Old 11-01-2006, 11:53 AM   #27
EFFalcon
Last warning
EFFalcon's Avatar
don't envy people paying for 5 speed conversions on AU's :o
they're so much cheaper on Eseries ;)
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 11-01-2006, 12:52 PM   #28
stiddy
stiddy's Avatar
of course E series conversions are cheaper...
if it cost the same as an AU the conversion would be worth more than the E Series car its in ;)
Old 11-01-2006, 12:56 PM   #29
justa6
justa6
justa6's Avatar
If it's going into au then au box is the only one that is the right lenght, au xr8 box is stronger then all the others, pretty much the same as z spec.
gee stiddy that's a harsh statement
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 01:07 PM   #30
EFFalcon
Last warning
EFFalcon's Avatar
lol... its funny coz its true
its also true that some AU's are cheaper then E-Series
