Old 26-12-2005, 02:21 PM   #1
f6 typhoon
Default rear doors on au series 2 don't lock
hi everyone i currently own a 2001 au2 forte and the problem is the central locking does not work any more they use to unlock but then not lock now i have a bigger problem the back doors don't lock at all anymore and help would be appreciated
f6 typhoon is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 02:58 PM   #2
carratt
I Love My T3
carratt's Avatar
I had the same sort of problem with my au2. The actuators in the doors become buggered after a while from all the slamming they receive. I picked up a new actuator from ftgautosalvage (site sponsers with their own setcion) and threw it in myself. Probably about a 15 min job and easy as hell to do.
Mine was jyst the one rear door though
carratt is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 03:50 PM   #3
JC
JC's Avatar
Ditto. My right rear door actuator went. FTG auto salvage to the rescue for parts,and it's easy enough to fit your self. Around $70 per door from memory.
Ford Performance Club ACT
Old 26-12-2005, 06:41 PM   #4
Bobman
Regulator
Bobman's Avatar
Oh and another thing.. this happens to taxi's all the time!
* NEVER * unlock the passenger door the same time as someone is opening it from the outside or your door WONT close and your actuator gets permanentley jammed.
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 07:49 PM   #5
GUTLES
Adam.
GUTLES's Avatar
ive had the same problem with one of my rear doors aswell..
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw
2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater.
2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob.
GUTLES is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 08:54 PM   #6
GTHOXR8
Same problem here. Actuator jammed when kids were friggen around with opening and closing door. Two weeks later the other actuator went out in sympathy. If you can fix it yourself, do so, because Ford will charge around $220 a side.
GTHOXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 05:59 PM   #7
f6 typhoon
thanks for your help fellas really appreciated i am going to do it on my holidays
Old 27-12-2005, 08:36 PM   #8
JC
JC's Avatar
A short term "security" fix for this is to remove the rod between the outside door handle and the door mechanism. You need to remove the trim to do this, but it's a fairly easy job. You can still open the door from the inside.
****IMPORTANT NOTE**** If you are going to do this short term security measure, make sure the child lock is switched so that the inside handle will actually open the door - if you don't, then you will never open the door again (at least not without a gas axe or similar tool).
Old 28-12-2005, 05:29 AM   #9
carratt
I Love My T3
carratt's Avatar
just my bloody luck it seems that my front passenger door has now gone aswell.
Old 28-12-2005, 09:53 AM   #10
Falcon Freak
Falcon Freak's Avatar
I had the same problem on the left rear door of my 1999 AU Forte.
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 10:34 PM   #11
Mechan1k
Mechan1k's Avatar
I have the same problem as well ... actually ... hold on ... I don't have any rear doors ...hmmm
Sorry bad joke ... I am on nightshift ... hee hee
Old 29-12-2005, 05:03 PM   #12
lv619
lv619's Avatar
Happened to me once when i tried to open a passenger door from the inside (instead of just pressing the central lock button). I just took off the door trim and put some wd40 on the actuator whatever and made sure that the rod thing wasnt bent. Havent had the problem since.
Me fail English? That's unpossible.
lv619 is offline   Reply With Quote Multi-Quote with this Post
