Old 01-09-2005, 06:58 PM   #1
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
Default Telling VCT from Non-VCT
Hi,
Have put a deposit on an AU3 6 Cylinder Engine, wondering how I tell if it is VCT or non VCT does it say VCT on the rocker cover if it is a VCT engine?
these are the part numbers from the block, head... and somewhere else; timing cover perhaps?
WR2A-6090-AC
WR2A-6059-AA
WR2A-6015-AB
if that helps at all..
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 07:02 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
it shouldnt come down to checking numbers, there is a huge mechanism on the front of the head, notched into the rocker cover..You simply cannot miss it :0)
Old 01-09-2005, 07:05 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
See it sitting right at the front, a HP or standard rocker cover won't fit so it should like the picture have VCT plastered across the rocker cover
Old 01-09-2005, 07:33 PM   #4
SileNceR
SileNceR's Avatar
aha!
its not a VCT then it says Intech 4.0L no angled stuff and its not red
that and its got the small downwards half moon at the front
211RWKW EA
Old 01-09-2005, 07:54 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
you didnt say it wasnt an XR my bad for the asumption..
The VCT was only on the XR's and luxury models...
Old 01-09-2005, 07:55 PM   #6
SileNceR
SileNceR's Avatar
Ah cool I wasn't 100% sure I thought by AU3 they might have been standard VCT across the whole range or something
211RWKW EA
Old 01-09-2005, 07:56 PM   #7
Casper
Contributing Member
Casper's Avatar
Nope. Probably the least made I6 Falcon engine (well, head really) ever. Its unmistakable, Red, has VCT on it and the VCT mechanism is like the proverbial dogs b....s.
Older, wiser, poorer.
Old 01-09-2005, 07:58 PM   #8
SileNceR
SileNceR's Avatar
I had no idea what to look for never really studied any AU's either...
211RWKW EA
Old 02-09-2005, 04:33 PM   #9
DJM83
Barra Turbo > V8
DJM83's Avatar
look under the rear ull see and IRS set up aswell indicating a VCT anyway ur paroblem has been solved
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 07:42 PM   #10
SileNceR
SileNceR's Avatar
I'm only getting the motor, not the whole car
Thanks anyway
211RWKW EA
Old 03-09-2005, 12:02 PM   #11
DJM83
Barra Turbo > V8
DJM83's Avatar
opp my bad
Old 03-09-2005, 12:05 PM   #12
Casper
Contributing Member
Casper's Avatar
What are you going to put the VCT motor into? Are you getting the ECU and loom too?
Old 03-09-2005, 03:09 PM   #13
Racecraft
they call me Tibbo
Racecraft's Avatar
aha!
Thanks anyway
He is transplanting an AU engine not the VCT..
Old 03-09-2005, 07:09 PM   #14
SileNceR
SileNceR's Avatar
Ya non VCT AU Motor into my ea
211RWKW EA
Old 04-09-2005, 02:35 PM   #15
Peuty
Afterburner + skids =
Peuty's Avatar
IS it possible to put a VCT head on a non VCT engine?
Oo\===/oO
Old 04-09-2005, 02:46 PM   #16
cArSiK
Yes , it is possible. The bottom end is all the same across the AU 6's.
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2005, 08:47 PM   #17
DanJar
hmm My XR6 has a Red engine, but it only says Intech 4.0L.... No VCT logo's..
-=DanJar=-
DanJar is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2005, 09:13 PM   #18
cArSiK
-=DanJar=-
Your XR6 must be an HP variant , only the up-spec XR6's Scored the VCT engine...Both Damn fine engines!
Old 06-09-2005, 09:19 PM   #19
DanJar
So the VCT is better than the HP engine?
Old 06-09-2005, 09:27 PM   #20
cArSiK
Technologically speaking yes it is , but in reality there isn’t a lot between the two performance wise as the VCT motor was paired up with an Independent Rear Suspension system that was 80kgs heavier than the live axle setup that the HP scored so that blunt its performance somewhat. The VCT system was designed to boost low end torque and give afew more KW’s ..... it is apparently abit smoother than the HP so i hear....
James
Old 06-09-2005, 09:32 PM   #21
Paxton
Cobblers!
Paxton's Avatar
Hell Yes. Especially between 3,000 and 4,000 RPM, which was the 'sweet spot' in my AU. It went like the clappers too. The Low Down torque was phenominal, and the high up kilowatts made the T5 option that I took out worth the physio I had on my left leg. What was that you said about yours Casper? :rolleyes:
-Andrew
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2005, 09:33 PM   #22
DanJar
ok, cheers... just reading through some old forum posts the vct vs hp topic.. a lot of info in there that I was not aware of....
Thanks... I'll have a further read through
-=DanJar=-
