Old 27-08-2005, 02:14 PM   #1
nat_daly
Nat D
nat_daly's Avatar
Default silicon spray
for an au falcon to fix the windows.... where do u get it from?
nat_daly is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 02:23 PM   #2
phildee
phildee's Avatar
I've seen it at Supercheap and Autobarn at least, i'd presume most places like that would keep it
Cheers, Phil
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 02:48 PM   #3
BlackLS
Yeap, most automotive shops should have them, I get mine from Supercheap like said in the post above, and its great for refreshing them rubbers when they start to stick. Some people also use it on body plastics for its shine but I notice it seems to attract the dust a lot more.
The way i applied it was, pull of the door trims, if the spray didn't come with the tubular nozzle, grab one from a WD40 spray (purge remainig wd40) or if ya really pov, use a maccas straw. Then I would start on the inside rails, high up. This is where it is most likely to stick. Open and close the window a few times, and if it still sticky moving, work downward, making sure you use it liberally.
Old 27-08-2005, 03:25 PM   #4
INJECTED_250
Custom user title
INJECTED_250's Avatar
MRsheen works great on window rubbers and doesnt wreck the rubber like silicone does
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2005, 03:52 PM   #5
nat_daly
Nat D
nat_daly's Avatar
yeah well i got some at bunnings hardware in case anyone else wants to know..
Old 30-08-2005, 08:14 PM   #6
GTHOXR8
I bought some at Bunnings last weekend for about $10. Its called ezy glide and often used to lubricate roller doors. I to used it to fix the power windows.
GTHOXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 04:59 PM   #7
Axle-F
AU - YEA YOU!
Axle-F's Avatar
So do you just spray the stuff inside the window rubber with the window down or do you have to pull the door trim off?
AU II XR6 VCT - JMM DEV3+
Axle-F is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 05:02 PM   #8
nat_daly
Nat D
nat_daly's Avatar
spray it in between the rubber down the sides of the windows...
Old 31-08-2005, 05:39 PM   #9
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I just used Inox.
Old 31-08-2005, 05:42 PM   #10
Sagerian
Custom User Title:
Sagerian's Avatar
I couldn't find it in any of the auto stores in sydney, ended up getting it in kmart of all places.
____________
Just sometimes, in between the first cigarette with coffee in the morning to that four hundredth glass of cornershop p**s at 3am, you do sometimes look at yourself and think... this is fantastic. I'm in heaven.
Sagerian is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 08:14 PM   #11
V8kado
Mondeo Titanium Estate
V8kado's Avatar
Just had my 2 front doors done today when my car was in getting serviced by a ford dealer.I told them about the windows going up slowly and i asked if they could squirt some lube in there thinking it was part of the warranty, come back in the afternoon to pay for the servive and the bloody smucks charged me $24.10 for lubing the door runners. ****ed off, I think i will head off to the auto shop next time and do it my self. Lesson learned!
V8kado is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:20 PM   #12
Sagerian
Custom User Title:
Sagerian's Avatar
Well now you know. I feel for you that you had to learn the hard way. Ford Servicing is a rip off unfourtunatly.
____________
Old 01-09-2005, 06:21 PM   #13
galaxy xr8
Giddy up.
galaxy xr8's Avatar
$24.10 for that, gezz. rip of merchant's.
Old 01-09-2005, 09:28 PM   #14
smee
FishermanDan
smee's Avatar
Should of asked them for the remaining contents of the can ;)
smee is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 06:22 PM   #15
6T
Now a turbo man - sort of
I didn't know silicone stuffed up door rubbers, so thanks for the tip. I was about to blast a heap of silicone spray into my window runners when I read your reply. Mr Sheen it is (good stuff for dirt bikes too, I found).
6T is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2005, 09:55 PM   #16
GasoLane
Former BTIKD
GasoLane's Avatar
This is a new one on me as well. Silicone usually provides protection from rotting on rubber.
Old 06-09-2005, 09:36 AM   #17
Sagerian
Custom User Title:
Sagerian's Avatar
Vasoline apparently works well also.
____________
Old 06-09-2005, 10:18 AM   #18
RED_EL_XR8
RED_EL_XR8's Avatar
Valvoline, Hell yeah, Lawsey uses it to get his jeans on!!
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2005, 10:21 AM   #19
Sagerian
Custom User Title:
Sagerian's Avatar
Well I actually said vasoline, not valvoline, but close.
Vasoline, you know what I mean.
____________
