Old 08-01-2017, 04:07 PM   #1
BuuBox
Default AU Radiator Cap
I feel silly asking this question, but bear with me...
The radiator cap on my AUII XR6 looks original and fairly worn out. Went to buy a new one, but no one (Repco, SCA, Autobarn, eBay) stocks a 120kpa / 17 psi replacement, only 135kpa / 20psi.
With radiator hoses possibly approaching 17 years old, I'm a little hesitant using one with a higher pressure.
The only alternative I can see is the Tridon CN15100, which is 100kpa/15psi.
Any recommendations?
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2017, 08:06 PM   #2
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
Default Re: AU Radiator Cap
I looked up the Tridon and CPC catalogues - they only list the 20psi caps. If your cooling system is in good order, this doesn't present a problem.
I can't comment on going to a lower psi cap, so I won't.
If your hoses are 17yo, then you've got a good run out of them. A lower psi cap is not going to save your ***.
Yes, it's a PITA changing out all the hoses, but best be planned at home to do it. Imagine if one of the hoses blows while out on the road and the inconvenience it would cause - let alone the cost of towing fees.
Replace the hoses now mate, that's the best advice I can give you.
Cheers!
Edit: Flush the cooling system and add rust inhibitor/coolant while your at it - your alloy cylinder head is expensive to replace, if it's not already munted.
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2017, 09:01 PM   #3
BuuBox
Good advice, but I'd still rather use a radiator cap that is equivalent pressure to the factory cap.
Old 08-01-2017, 09:25 PM   #4
Tickford.
🚫⏰4️⃣🐃💩
Tickford.'s Avatar
Makes no difference that you will notice. Thousands of AUII XR6's have the 20psi cap on with no issues whatsoever, as it's the most common cap available.
Going with your theory, have the tyres being replaced with the original spec tyres? Or the brake pads with the exact same spec as it came from factory?
Tickford. is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2017, 12:21 AM   #5
snap0964
3 PSI is bugger all - old age hoses, well, that's another thing.
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2017, 08:10 AM   #6
Sox
RIP...
Sox's Avatar
It's not a good idea to increase the pressure of the radiator cap over standard, the system may not be able to handle the increased pressure.
However, AU2/3 spec is 15-20psi, so you'll be ok.
Your hoses may still be fine, if in doubt, replace them too.
Oval Everywhere...
Old 09-01-2017, 08:51 AM   #7
Sox
RIP...
Sox's Avatar
The Tridon catalogue has caps listed from 7psi to 20psi (and everything in between) to fit an AU.
Oval Everywhere...
Old 09-01-2017, 09:35 AM   #8
Fed
Buy a genuine Ford one.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2017, 09:34 PM   #9
BuuBox
Thanks, you're right - the service manual on here specifies 120-135kpa.
Do you have a part numbers? I can't see them on the website.
Will do, if I can get to the spare parts counter before they close. I'm not actually chasing an issue here, just replacing a worn looking cap. Don't want to create a problem unnecessarily.
Old 15-05-2017, 11:31 PM   #10
Interceptor
HSV - I just ate one!
Interceptor's Avatar
IIRC VY V8 commodores have a 120kpa cap
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is online now   Reply With Quote Multi-Quote with this Post
