can someone please tell me where are the removal points on xr8 engine.
you have a hitch at rear of engine but nothing at front. i use bolt put thru chain into the exhurest nut thread?? worry bend the rocker cover?? please need advice thanks |
Irregular member
I removed a V8 recently and it had a removal loop bracket bolted into the first two header bolts on the passenger side. Maybe get one of those?
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
#3 | |||
wonder where i canget one from ?? |
Irregular member
Yes, on that side. I looked on eBay but cannot find anything. Maybe try a wrecker?
ive never seen them on them. interesting
![]() Join Date: Oct 2006
These should fit http://www.ebay.com.au/itm/FORD-EB-E...oAAOSwbdpWXTjN
regards Blue |
Irregular member
That's it!
#9 | |||
regards Blue |
RIP...
That's what I did.
I mentioned it so people with XR8's will know why they don't have them.
. Oval Everywhere... |
#12 | ||
what way should i unbolt engine from Mount?
the bolt that goes thru mount and chassie ...or... two bolts thru mount on engine ? will be putting anthor engine in. thanks |
Irregular member
I undid the bolt that goes through the chassis, one spanner on the rear to jam it from moving, ratchet on the front. Then I removed the mounts from the engine once it was out.
I would say this would be the easiest way when putting the new engine in since they will help locate the engine to the chassis.
