Old 19-03-2013, 07:04 PM   #1
elmonas
Question Au v8 coil pack
Any ideas guys
One of my coil packs spark is only coming out of 3/4 of outputs
Is this unusual?
Are the Super Cheap generic brand coil packs any good? If not what is the
best brand to buy.
Should I replace both?
elmonas is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2013, 07:18 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: Au v8 coil pack
How did you determine only 3 out of 4 were sparking ? If they are the originals it would be time to replace MSD or VDO are pretty good options check E bay they list a few at reasonable prices and yes Both would be a good idea
Originally Posted by Riksta
Old 19-03-2013, 07:49 PM   #3
elmonas
Spark only came out of 3 of them whilst holding the lead out of them, then tried to earth the fourth one but still no spark
Old 20-03-2013, 11:24 AM   #4
RG
Back to Le Frenchy
RG's Avatar
Pretty common, well very common actually.
Replace with MSD is the usual option, part# MSD8241.
Old 25-03-2013, 09:17 PM   #5
bluestripes
Q - CAR
bluestripes's Avatar
http://www.summitracing.com/parts/msd-8241
CLICK THIS LINK. .. THESE ARE THE BOMB
AU FORD STROKER
347 Windsor Stroked; (10:2.1) / TFS 190 heads / TFS R Series 90 manifold / Accufab 85mm Race TB / 90mm Lightening MAF / K&N 90mm pod CAI / FTI custom cam (230-236 @ 50) / Bosch 36lb inject / MSD coil + leads / ASR 8lt sump / Mcleod RST Twin Plate Clutch / Pacemakers PH4006 + 3" single exhaust / BA Premium brake pac / Pedders Xtreme coil over shocks / 30mm Whiteline sway / 3.45 LSD / Custom FG bonnet / Ghia interior upgrade / Enkie Rims - staggered / Quarter Horse tuned.
bluestripes is offline   Reply With Quote Multi-Quote with this Post
Old 27-03-2013, 11:31 PM   #6
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
I'd first try swapping out that lead as it sounds like you were still trying to use the same lead to see the spark between the coil and the lead. If the lead is shot the coil isn't going to be able to push a spark through air to a lead that is too shagged to help it get that spark to earth...
Yell out if you need help, I'm in Melbourne's south-east and have 2 spare leads (the long ones!) and coils.
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
