Hi all,
Does anyone know where I can get some Side Door Mouldings for my Focus? I have seen some cars with color matched mouldings or close enough and they look pretty good, I had some pr^&K open their door on my car which left marks but no dent. I tried to buff out the marks but Ford paint is way too thin, now I have a light spot which I would like to cover up and stop the Ba#$%^& from doing more damage. Thanks Noel
1400 GTR Goes like it has a Kwaka up its butt |
You can call me Chris
not sure where to get them, but they actually have lugs that go into holes in the doors.
I'm sure you can cut them of tho!
'06 LS Focus Hatch -2 1/4" Lukey Exhaust -RDA Slotted discs/Greenstuff pads -Rear Whiteline swaybay -Lenso 18's w/Kumho rubber -Tinted Windows |
Old enough to know better
My door mouldings (LR) are colour coded, but they are the original black ones I had spray painted
Manual 2003 Machine Silver 5 Door LR Focus Zetec. Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior. www.cardomain.com/ride/2773918
Hi Champ, I realise these are in the UK, but postage will only be about GBP3-5.
Cheap way around it if these are what you're looking for! http://cgi.ebay.co.uk/Ford-Focus-N-S...es_CarParts_SM http://cgi.ebay.co.uk/Ford-Focus-N-S...es_CarParts_SM Cheers, Leakey
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR |
Torquer
I had mine fitted and painted by the dealer when I bought the car, they are genuine Focus ones that are just stuck on with glue. Your service centre should be able to order some for you but they will be black and most likely cost a fair bit.
Any aftermarket ones look garbage in my opinion. |
Knows nothing. Apparently
The LS came standard with side moldings but they were deleted on the LT. I'm pretty sure the door skins haven't changed though so you should be able to fit those.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!! ![]() 1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here |
Eat my Brake Dust
As stated above the door mouldings on the LS are glued and have clips that fit into holes in the door.
Whether you cut off the clips and just rely on glueing it on or cut a hole in the door to fit the clips you should be able to make em fit. Mind you the side mouldings didn't stop a small dent on the rear passenger door from some disrespectful twerp throwing his door open.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club ![]() ![]() |
Thanks guy's
![]() My Focus is Silver so I guess the gray will look OK on Silver or I could paint them I guess ![]() Noel
Torquer
They look very close to original, I'd go for them. Painted would look much better if you can do it properly.
Getting them on straight and perfectly aligned on both sides will be a fun job! |
