23-04-2010, 01:07 AM | #1 | ||
Well guys as my signature states i intend to convert my AU wagon to V8 sometime this year. I have had a think and it is possible if i get my rear end into gear i could have everything sorted and ready to go in my mid year break from uni. (2 weeks)
I have a stock 175/185kw V8 out of a 2001 XLS ute, along with the gearbox, and bellhousing from the same ute. I have a couple of V8 clutch cables and all of the accesories ie water pump, power steering pump etc. This is due to me stripping the entire motor and gearbox out of the ute. I also have picked up a series 3 XR8 ute ECU which is compatible with my car (being series 3) and the entire wiring loom from gearbox to motor and through the firewall to connect into the ecu. Along with the exhust of the XR8 ute. I also need to get appropiate paper work from either ford or a qualified mechanic to say that the brakes, suspension and structure of the car meet or exceed that of a fairmont V8 wagon which used the same effective (power rated) motor as the one i plan to use out of the ute. I have a few questions however so if you can help in anyway that would be much appreciated. # Are the power steering hoses different from 6cly to V8 (pretty sure they are but not 100% and i don't know where i have put them if i kept them)? # Will the stock 6cly wagon fuel pump do for the time being or not if not what would be recommended keeping in mind i will either stroke this motor or get a 347ci crate motor? # Is it possible to keep the aircon in the engine bay (removed from the motor) to avoid having to regas it? # Will a 6cly radiator be ok for now or not? # Are the throttle and cruise control cables the same? # Is the 'K' frame suitable for both 6 and 8 cly motors or not? # Would i have to have it flash tuned as it will be running a stock XR8 ecu but with a base v8 sith only XR8 exhuast and intake manifold?? # If i have everything ready and go ahead in the mid year break i will be limited on time however if the motor comes out should i look at getting the firewall reinforced where the clutch cable comes through. Also should i take out the pedal box and get the clutch pedal reinforced?? # Also is it hard to change the intake manifold from the base one to the XR8 one and is there any point. ie; are they actually different?? Also just trying to get an idea of how much this is going to cost me. New clutch kit $350 Gasket kit for intake and exhuast manifold $50 Tune ECU to car at ford $121 (had this done to get the manual ecu sorted) towing down to for to get ECU tuned $100 Exhaust tailpipe (different to ute one) $150 Oil filter/ fuel filter and oil $150 Raditor if needed will be getting a good one $500 Flash tune if needed $1500 Total $3410 is there anything i am missing or anything i have got wrong in terms of costs or what needs doing. Pretty much if i go ahead in the break i want to know exactly what i need to do and how much it will cost. I have now got the funds due to selling my old wagon so i want to hopefully do it before i spend the money elsewhere. I have to say a big thanks to anyone who can offer some help in any shape or form as it is much appreciated. Cheers, Rhys
Toy Car Build |
23-04-2010, 10:28 AM | #2 | ||
I wouldn't have a clue about the majority of your questions but I can tell you that the Explorer manifolds between the 175 and the 220 are the same. It was the Heads that were ported.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
23-04-2010, 10:48 AM | #3 | |||
GT 335 11.3@124.1mph 383rwkw/513rwhp Forced Performance Tuned |
23-04-2010, 10:52 AM | #4 | ||
I don't have answers for you but a question..Would you be selling the 6cyl T5 (and the whole conversion stuff provided you can't/don't use it for the V8)
23-04-2010, 09:44 PM | #5 | ||
when you put it in, it will look like this
Ray
Daily: AUII V8 Fairmont Wagon - Organza Auto Stroked aufalcon.com.au Fun: BA/F I6 Turbo Tsunami Wagon - Red 6 speed Auto Street Fords Issue 27 Sold :( |
23-04-2010, 09:46 PM | #6 | ||
i wish lol
24-04-2010, 12:35 AM | #7 | |||||
Yeah well i hope. Is that a T-series motor?? Looks very very clean i approve Quote:
Toy Car Build |
24-04-2010, 12:05 PM | #8 | ||
Yes, it is a 5.6 T series motor
27-04-2010, 12:00 PM | #9 | |||
Just a bit of an update: Bold is new stuff
Toy Car Build |
27-04-2010, 12:39 PM | #10 | ||
Also just one other quick question can you do a compression test on a motor when it is out of the car??
Toy Car Build |
28-04-2010, 07:38 PM | #11 | ||
Hit what could be another problem today. The power steering coolers are different between the v8's a 6's and the v8 one i have is busted. Plus they are obsolete from ford so just wondering is there a good quality aftermarket part?? Or what would other people suggest. Just get one made up from some piping?? Or could you use a small auto cooler??
Toy Car Build |
01-05-2010, 01:13 AM | #12 | ||
Can't use something from a B Series car for your steering cooler?
BAII XR6 in SHOCKWAVE 5SP Manual | Sports Leather Seats | Premium Sound | Dual Zone Climate Control | Sunroof | Reverse Sensors | 18" XR8 Wheels | XR6T Exhaust | Lowered | XR6T Intake | GT Steering Wheel AUIII XR8 in NAROOMA BLUE Info to come soon! |
