Old 15-10-2009, 09:13 PM   #1
R0BD0G
R0BD0G's Avatar
Default what parts can i change over.. crossflow 1.3 - 1.6?
as above.. was wondering what parts i can still use. i assume head and exhaust and intake manifold will all bolt up.. anything else?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2009, 06:33 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
all external parts are the same, the only difference between 1300 & 1600 is the block is about an inch taller...
Did you pick up a twin barrel webber carbie at the same time? in early 1600 is was the GT carbie, later model MK2's had them as well
cheers mate
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 16-10-2009, 07:47 PM   #3
R0BD0G
R0BD0G's Avatar
cheers mate
sorry im a bit slow tonight... by external parts is head included.. or do u just mean the manifolds... also its the same bolt pattern for the gearbox isnt it?
Old 17-10-2009, 12:14 AM   #4
SLO AU XR8
External parts is fuel pump, accessories (alt etc) basially anything that bolts on to the block
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2009, 09:05 AM   #5
Puzzlescort
Rally Nut
Rob
gearbox, head, waterpump, manifolds alternator, carbie, sump, dizzy, cam, followers
the engines are the same bar the 1600 has a longer stroke
you just need to match the same style of head to the pistons - what I mean is if you have a flat head, you will have dished pistons, if you have a head with combustion chambers you will have flat top pistons.. thats about the main thing to consider if you are swapping heads etc
(I have to have another look, I think I saw a twin barrel carbie in a box of crape, if its for a 1600 & you dont have one, its yours...)
cheers
Old 17-10-2009, 12:58 PM   #6
R0BD0G
R0BD0G's Avatar
how will i go using the 1300 GT HC head on the 1600? im asuming the motor im getting has dished pistons. and the 1300 should have had 9.0:1 compression?
Old 19-10-2009, 06:18 AM   #7
Puzzlescort
Rally Nut
As long as you use the same types of Pistons you should have the same compression ratio as a minimum - with the flat cyclinder head the compression ration is gained from the block & piston height
