Old 04-09-2009, 03:50 PM   #1
tickford2001
Default Mk1 2L
hi all, im just in the process of fitting a 2L engine into a mk1 escort
ive been told that i will need to modify the radiator support panel to fit the 2L radiator (which i dont have yet). now i like to make things look as factory as possible, so im just wondering if anyone has any photos or diagrams to show how a factory Mk1 RS2000 radiator support panel is shaped?
thanks in advance for any assistance
cheers, dave
Gone cruising
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2009, 04:06 PM   #2
Busted
Busted's Avatar
Years ago when I put a 2lt into a mk1 I just cut the side plates off the radiator that you would use to bolt it the rad support. This made it posable to put the front harlf of the rad through the dap support. No cuting of the body in any way & looked factory.
Busted is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2009, 06:34 AM   #3
Puzzlescort
Rally Nut
Puzzlescort's Avatar
Dave
the cut out people talk about is removing the top of the radiator support to allow the radiator to sit further forward than the cross flow rad.
there is also a recess in the front on the bottom running the width of the radiator as well
hopefully from the pic you can see the radiator brackets are opposite the the original rad for a crossflow
http://i560.photobucket.com/albums/s...t/CIMG0574.jpg
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2009, 09:49 PM   #4
tickford2001
thank you very much - i see exactly what i need to do!
think i might try cutting the ends and folding it neatly under the rad support to try and make it a little stronger than just cutting it out
thanks for your help!!
