30-01-2009, 07:11 PM | #1 | ||
SKID IT
hey guys, ive been driving my oldmans au ute while im getting the head done on mine,
when im driving up a hill and the engine is working the temp gauge shoots through the roof but the engine is not getting hot at all? what causes this? wha can i do to fix it? cheers :
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
30-01-2009, 07:24 PM | #2 | ||
Sales Representative
that can be caused if the water is a little low and the gradient of the slop is high enough for the sensor to not actually be submerged in water... top up the tank a little more, check it over a few days and see who much water you loose... see if it does it again also...
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
30-01-2009, 08:12 PM | #3 | ||
SKID IT
i did notice it was a little low only about 3 cm from the top, ill top it up before i drive home tomorrow and see what happens
thanks mate
30-01-2009, 08:23 PM | #4 | |||
30-01-2009, 09:09 PM | #5 | ||
SKID IT
too easy
31-01-2009, 03:54 PM | #6 | ||
Smile
The au temperature sensor doesnt sit in the water jacket. You may have a dead thermostat so get another head ready if you dont read my post in time.
It may just be electrical though..
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
31-01-2009, 09:03 PM | #7 | ||
Boost Addict
also if temp sensor fails thermosw wont work either
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
03-02-2009, 09:19 AM | #8 | ||
Not sure on the AUI ... but I know AUII uses a Engine Cylinder Head Temp (ECHT) sensor in the driver's side rear corner of the head ... and as Stav mentioned it doesn't going into the water jecket ... just into the alloy only. If the temp sender fails ... your gauge will read off the top or the bottom all the time.
Id suggest if it's a load issues on a hot day ... it maybe a water pump corroded out (literally no internal vanes left) ... if doesn't need to be leaking for it to not work efficiently. I was lucky enough to find that out when trying to troubleshoot an overheating issue myself. I gave up in the end though ... and traded my ute in before it got to Summer again. I ended up replacing: Header tank. All hoses ECHT sensor radiator (with a twin core) water pump moved the external trans cooler thermostat (twice) I also had the thermofan relay mod done as well ... as soon as A/C is turned on .. the thermos come on High speed (until you turn the A/C off). Also tried to replace the head gasket thinking it was that ... the head wouldn't part ... so I just put a replacement engine in it (only had 60,000km on it) ... was cheaper in the long run ... also replaced my auto at the same time for one that was built up for boost applications. As I said ... gave up in the end and got rid of it.
