Old 02-12-2008, 01:31 PM   #1
scorpio39
Default Fuel Pump or Injectors ?
My '99 dual fuel ( 125 Klms ) runs ok on gas but I'm experiencing a lack of power on petrol.
At first I thought it was a blocked fuel filter and replaced it, as a result no change in performance.
I had a mechanic look at it and he said it was either injectors or fuel pump and wants to replace both.
I figure that as both petrol and gas go through the injectors, the injectors would be ok.
Am I correct in assuming this ?
Any thoughts guys ?
scorpio39 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2008, 02:04 PM   #2
MGGT RAA
AUII XR8, BA XR8 290 UTE
MGGT RAA's Avatar
Has it always been like that yeah? i had an ef duel fuel that went hard on gas and pretty sluggish on fuel, i was told that it was just tuned to run favourably on gas...
AUII XR8 220 Build : Blown 380HP 810NM - http://www.fordforums.com.au/showthread.php?t=11253752
BA 290 XR8 Ute Build -http://www.fordforums.com.au/showthread.php?t=11271242
MGGT RAA is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2008, 02:11 PM   #3
Busted
Busted's Avatar
Any thoughts guys ?
I don't think that the gas go's through the injectors. How ever why dose he want to change the injectors you can have them cleaned. Has your pump been presser tested?
Busted is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2008, 09:20 PM   #4
scorpio39
Default Sluggish
Only in the past month.
Old 02-12-2008, 11:07 PM   #5
bodes-sh
lpg does not go through the petrol injectors. get the fuel pump changed first, they aren't too expensive, i got one of the cheapie ebay jobs about 18 months ago and haven't had any problems with it.
Old 02-12-2008, 11:12 PM   #6
mik
mik's Avatar
have you tried running a bit of injector cleaner through fuel system? i have no clue if it will make a difference but i would give it a try first ....its cheap.
Old 03-12-2008, 06:43 AM   #7
au2sw
Blown 5L coming
au2sw's Avatar
dont go racing out to get injectors and pump replaced!!! first things first, find a work shop that can pressure test your fuel system and clean your injectors. both these wayas are much cheaper then replacing the items straight off the bat. my guess though would be that the injectors need a good clean. my fuel pump seemed ok until one day i couldnt really drive around on petrol, it'd just stall and i couldnt even tap the throttle without it stalling. once i changed that all good. i got out of that really cheap though...free in fact. working at a LPG conversion center where we pull out petrol tanks on 4wd to fit LPG tanks, i simply used one of these pumps (landcruiser one) required a bit of a re-wire, but it took me all of 5 minutes....once i had dropped the tank out of the wagon!!! in a sedan its easier to do as the pump is accessable throught the floor in the boot.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2008, 10:08 AM   #8
scorpio39
Many thanks , guys !!!!
I'll get them to pressure test the fuel line first which will indicate one or the other.
