Old 17-10-2008, 12:27 PM   #1
TheSly1
Default How To Remove Inhibitor Switch
How do you remove the inhibitor switch on the AU Transmissions? I can get the 2 wiring plugs off and the 2 8mm bolts.
But can work out how to get the switch itself off.
Any suggestions? I dont want to break it.
TheSly1 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2008, 01:23 PM   #2
NYTEYZ
Hey TheSly1,
I'm guessing your talking about the 'econ/power' switch on the bottom left of the t-bar?
NYTEYZ is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2008, 01:49 PM   #3
TheSly1
Sorry I should have explained, on the transmission under the car (pass side) there is a white object with 2 wiring plugs and part of what it does is makes it so u cant start the car in anything but park amongst other things.
I need to remove this.. There are 2 bolts and 2 wiring plugs which ive removed but it wont come off and i dont want to break it..
Originally Posted by NYTEYZ
Hey TheSly1,
Old 24-10-2008, 07:33 PM   #4
EL_Mont
You're doing it right, it's just two bolts holding it in as you said, but the shaft in the centre tends to rust a bit over time and bond itself to the plastic making it hard to take off.
Just have to pry it off as straight as possible but be very careful.
Once you do get it off, make sure you sand down the the rusty shaft so when you slide the switch back on (or a new one) it goes on smoothly and easily.
EL_Mont is offline   Reply With Quote Multi-Quote with this Post
