01-02-2008, 04:26 PM | #1 | ||
CRE.87V
hey most would know of my au xr manual....it has gotten a really rought idle sounding like its going to stall....when i give it a bootfull i can smell fuel...the exhaust is pretty fuely and build up of black smoke of tip....ata constant idle range the car sort of surges...
car had new ford plugs last week,,, inejctors cleaned at 115000..it has 128000 now...leads changed at 115000 to....could this be fuel pump or mapsensor...reg changed at end of dec.... |
01-02-2008, 05:33 PM | #2 | ||
Smile
Run the engine and look for leaks at li`nes injectors etc.If not that then your ego sensor sounds cactus and may need changing.
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
01-02-2008, 06:44 PM | #3 | ||
CRE.87V
yeh theres no leaks....changed the o2 sensor at 102000
01-02-2008, 10:25 PM | #4 | ||
try cleaning the map sensor if you can and go from there i guess
02-02-2008, 09:26 AM | #5 | ||
I had the same symptoms when I first bought my AU, which I got fixed under warranty, I am no mechanic, but I was told it was the fuel pressure regulator was not working properly, squirting too much fuel into the injectors.
After that was fixed, that went away, but to this day, my car sucks fuel like crazy when its cold. :-) From what I have read, thats just the warm up routine. Its fine once its warm. Hope that give you some help. |
