Old 02-11-2006, 07:34 PM   #1
Peej
Default Tyre Pressure
Hi all,
Just wondering, for those that just have stock wheels, how many PSI you are putting in them?
Peej is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2006, 07:42 PM   #2
Ives
Ives's Avatar
195/50 R15 or 195/45 R16?
Anyways, I ran 32psi front and rear (195/50 R15). I felt that it was the best pressure for me.
Old 02-11-2006, 10:20 PM   #3
Peej
195/50 R15. I run 32psi as well. The car book says 29psi.
Old 02-11-2006, 11:07 PM   #4
Piotr
Non-Regular Member
I have stock 195/50/15's on and I run 36front and 34back.
Ud be surprised what difference even a slight variation to tyre pressure can make.
Old 02-11-2006, 11:17 PM   #5
photn
AFF Post NAZI
photn's Avatar
high i have 205/40/r17 (yes i know there not stock) and i run 40 in the front and 35 i the rear
Old 02-11-2006, 11:27 PM   #6
BlackLS
Try switching those pressures, it should handle a lot better.
Old 03-11-2006, 08:31 AM   #7
Scareybear
GRRRR.....
Scareybear's Avatar
I run 40psi all round in my 17's feels good & wearing nice and flat.
Note: ALWAYS run a higher pressure than what the manuel recommends that way you'll get longer life out of them.
Now - 2007Renault Megane sedan, Steel Gray, 19" Koya Ambush with 235/35R19 Yokohama ADVAN V103, Eibach Pro-Kit.
Gone but not forgotton - Diamond White 2004 LX Fiesta
If you sneeze with your eyes open, do your eyes pop out??
Old 03-11-2006, 09:55 AM   #8
0xyg3n
0xyg3n's Avatar
I run 38psi all round on both my sets of yoko's and falken's I have yokos have worn flat. Falken's are still new so yeah cant report back on them yet.
0xyg3n is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2006, 10:47 AM   #9
Ives
Ives's Avatar
Yeah the tyre placecard recommends 29psi front and 26psi rear. But I figured that the fuel economy would be abit better at 32psi because of less rolling-resistance n stuff.
If I go harder than 32psi, the car feels too stiff and the tyres dont absorb the bumps as a well as i like it to be. Remember that tyre pressures can increase 1-2psi when they're warmer/hot.
Old 03-11-2006, 12:37 PM   #10
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Generally, i find putting 10% over the log book recommendation is a starting point.
People who know their cars will feel the difference between a few PSI. however if you do a lot of freeway driving or driving with a heavy load than the 10% above recommendation is a minimum.
pump up your tyres when cold and experiment with what feels good, you will soon tell what makes the car feel sloppy and what makes the car turn and feel more solid on the road.
Old 04-11-2006, 04:17 PM   #11
nnng_oozie
Bone Stock Fiesta!
I've still got the standard tyres and wheels. So i'm usually running at 36 all around. However on the track obviously i'll drop it down to 30-31 psi cold.
nnng_oozie is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2006, 04:33 PM   #12
Steffo
LPG > You
Steffo's Avatar
I've got the 16's with 195/45 R16 80V's (the same Continental ContiSport Contacts that were on it when I bought it) and run 31 psi front, 29 psi rear.
Old 07-11-2006, 10:45 PM   #13
RichieMK6
Panther Black MK6
RichieMK6's Avatar
40-41 taking into the mind the PSI will rise abit when the tyres warm up
AP1 on its way
In development stage 2
Carnt wait for the day ,NA all the way ,9000rpm with the top down
RichieMK6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2006, 06:27 AM   #14
Ives
Ives's Avatar
^^^ what size of wheels do u have on, richiemk6?
Old 10-11-2006, 03:32 AM   #15
RichieMK6
Panther Black MK6
RichieMK6's Avatar
stock rim
AP1 on its way
Old 19-08-2014, 12:36 PM   #16
quantumleaper
Default Re: Tyre Pressure
Hi All,
Recently purchased a second hand 2008 Fiesta with 17 inch rims. They are all pumped up to 37 PSI. This seems a little high to me but I don't know as 17 inch is not specified in the owners manual.
Any recommendations on what to run them at? I can get more specific info on the tyre make and model/size if it will help.
Thanks a lot.
quantumleaper is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 03:21 PM   #17
Swoopdown
Swoopdown's Avatar
sounds alright.
look at the tyres for any uneven wear and the tread condition will give you idea.
ive tested 38, 32 psi and settle on about 36 for the Stock potentza 205/40-17
might try the lower rear tyre and see how it feels
Swoopdown is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2014, 03:26 PM   #18
quantumleaper
Originally Posted by Swoopdown View Post
sounds alright.
ive tested 38, 32 psi and settle on about 36 for the Stock 17" potenza re050 rubber
OK thanks I'll take a closer look.
