29-08-2006, 07:19 PM | #1 | |||
I Like To Shake It
Hi there;
I think my drivers window motor is cactus, the switch will operate the passenger but not drivers, hence why I think its cactus. Could someone tell me if I am on the right track, and if any problems may arise with the removal of the power window motor. After removing trim One. remove three motor retaining screws Two. remove two window clip / regulator screws at the top I havent removed the top to screws as I thought the glass may come down... (yeah coward....) Any hints. Regards Paul
Regards Paul 2016 S550 TY GT Coupe....some loud bits and some glass bits I like My GT SHAKEN, and Blown Happiness is a TY S550, a 1911 semi automatic, and the Lovey Lizzie by my side. Quote:
29-08-2006, 08:55 PM | #2 | |||
Made the 300 :0)
New Owner of a fiesta ST |
29-08-2006, 09:16 PM | #3 | |||
I Like To Shake It
ratio 3.99
Thanks, I checked for power and all is okay there. Regards Paul
29-08-2006, 09:24 PM | #4 | ||
___________
There was a little trick you can do to reset the power window, I think you have to flick the switch 31 times up and down. Try that before you remove it.
29-08-2006, 09:59 PM | #5 | ||
FTF Club Moderator
FPV GT try this it worked for me.
http://fordforums.com.au/showthread.php?t=17267 The contacts on the power window switch may be dirty and there fore contact is not being made.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
30-08-2006, 02:38 PM | #6 | ||||
I Like To Shake It
Carbon 'n' crud build up is a common fault with au switches, my XR8 had that problem. I have swapped the working switch over, but alas no go, thats why I think the motor is shot. Regards Paul
