Old 18-04-2011, 02:44 PM   #1
Pube
Default WQ Fiesta starting issues
My girlfriends WP fiesta has an issue starting. It cranks normal, fires (sometimes) then dies. When it does fire it will run for a second but the electronic throttle pedal doesnt seem to be communicating with the throttle body, as in you pump the throttle within that second of run time but the engine does not rev.
It seems to be getting worse, yesterday it took 4 times to start other times it runs straight away. Anyone else had this?
2006 BF XR6 TURBO JTG LPG
Pube is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2011, 07:44 PM   #2
fiestaz
fiestaz's Avatar
Default Re: WQ Fiesta starting issues
Yeh I had the exact same problem. Got worse as winter came. Turned put to be the battery which I knew was on the way out as it would crank slowly.
Replaced the battery late last year, and hasn't done it since.
fiestaz is online now   Reply With Quote Multi-Quote with this Post
Old 11-06-2011, 11:03 AM   #3
philg
Mine has started doing the same. Did you replace the battery?
philg is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2011, 04:03 PM   #4
Pube
yep new battery, all good now
Old 16-06-2011, 04:07 PM   #5
csv8
csv8's Avatar
My battery is 4 years old!!! must be getting near its used by date !!There is a later PCM calibration..It was installed in my WQ on tuesday, when it had its 40k service...
CSGhia
csv8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-06-2011, 11:24 AM   #6
philg
Thanks. Off to replace mine. It's only lasted 5 years!
