04-02-2009, 02:23 PM | #1 | ||
After starting the car (AU1) the airbag light flashes 3 times then 2 times, does this several times and then just stays on. I've tried searching and from what I found this would mean error code 32? Driver airbag circuit open? Is this right?
I've checked the fuses and they are fine, Is there anything else I can check? Cheers.... |
04-02-2009, 08:06 PM | #2 | ||
When in doubt, GAS IT!!
If everything else looks ok my guess would be the clock spring in the steering column. It happened to my wagon so I just went to a wrecker and picked up a replacement and fitted it myself. Hardest part about the job was finding someone with the correct 5 sided torx bit to get the airbag off. Once that was done it was a breeze.
Bushbasher
04-02-2009, 08:09 PM | #3 | |||
Check, pull apart and clean all connections under the seats.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
04-02-2009, 08:19 PM | #4 | |||
That might explain why the horn doesn't work as well. I've changed one in a XH ute before but it didn't have an airbag. I will check the connections tomorrow... |
