11-11-2008, 07:34 PM | #1 | ||
Formerly MR BAXR6t
Hi all
Last couple of days ive got a knocking noise comung from the front drivers side wheel. It only really happens when turning. How can i explain..... Say im turning right, as soon as some "weight" is put on the wheel i get 1 clonk. Now i wont get another clonk if i turn right again, only if i turn left, and vice versa. Hope that made sence?? Any advice appreciated Cheers Frank
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
11-11-2008, 10:30 PM | #2 | |||
Blown 5L coming
have you lowered the car? its possible that the strut is starting to give out and as you turn it allows the spring to move giving the clunk. it wont happen again until u have turned the oppisite directio n to unsettle it again. try tightening your strut bolts (17mm nuts). but it is definitly spring related if its just one clunk when u turn until u turn the opposite direction and back again.
good luck
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
12-11-2008, 01:01 AM | #3 | ||
Sounds like a ball joint to me, i've just had to replace mine doin similar.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm. |
12-11-2008, 05:57 AM | #4 | ||
[ 5L ]
mine does it on hot days, im guessing steering rack for my car.
on cold days or nights it doesnt make a noise at all though. and i barely drive in the day anyway so it is on the waiting list.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
12-11-2008, 06:32 AM | #5 | |||
Blown 5L coming
ball joint is a constant knocking...this is one knock untill he turns opposite direction and back again. and shane yours may be ball joints too. next time ur driving through the day...listen for it. the knocking will be more audible while driving along and hitting bumps in the road as it travells with the suspension. mine did this and i was completely lost as to what it was as the knocking was only occuring on hot days or when i had been driving a certain distance. i had even checed the ball joints for movement, but they were fine when they were cold. one day i checked them after a long drive and was getting really annoyed about the noise....sure enough, it was ball joints. all i did was lift the front and move the stering left and right and grab the tyre at the top and the bottom adn push the top and pull the bottom a couple of times and i saw ....and heard, enough to confirm that it was the ball joints. i replaced top and bottom, work on about $15 each, and the bottom ones are usually cheaper. be sure to do both sides, as usually if one side has gone, the other side wont be too far off.
12-11-2008, 07:32 AM | #6 | ||
LIFELONG DJR SUPPORTER
Sway Bar D rubbers!
12-11-2008, 03:28 PM | #7 | ||
Sway bar D bushes tend to cause a constant rattling bump, especially over small bumps in the road.
It wouldnt hurt to have a suspension mob have a look underneath it. Even if its just something thats loose; shock mounts, ball joints, even some bolts being a tiny bit loose can cause the bump that you're talking about.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
12-11-2008, 06:24 PM | #8 | ||
Formerly MR BAXR6t
Thanx for the iput guys wil check it out this arvo
cheers frank
13-11-2008, 10:24 AM | #9 | |||
13-11-2008, 10:40 AM | #10 | |||
Back to Le Frenchy
I had the exact noise you are talking about, only when turning and only when going slow. It was a sort of crack/clunk noise and would only happen when the wheels were turned right hand down and then I'd get the same thing going back left hand down.
Replaced ball joints and the noise was gone.
13-11-2008, 10:43 AM | #11 | |||
Just another mock-up..
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
13-11-2008, 06:20 PM | #12 | ||
Thank you thank you thank you this is exactly what I'm having and it's driving me nuts!
