Old 30-12-2007, 11:33 AM   #391
Papa Smurf
Papa Smurf's Avatar
Nearly all BA brake lines (rear) have been replaced. Those with BA's should contact their local dealer if the rear lines haven't been changed yet and see if their car is covered for a replacement.
One thing I am curious about, all you guys that do this BA or AUIII brake change, do you also change the Booster? AUI has that crappy plastic one and I just wondered if any of you change that as well?
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2007, 11:34 AM   #392
blackers10
blackers10's Avatar
alot of the people do eventually change the booster
not always straight away it seems
Old 30-12-2007, 12:15 PM   #393
MADED-6
MADED.6
MADED-6's Avatar
ok so for au1 its alot harder/u need more parts for it yes?
would a booster change help peddle feel coz my au1 has shocking peddle fell ive tried bleeding it like twice with no change.
ive checked for leaks and cant find any and its kinda annoying its really spongy.
but wen i bleed it its good then i start the car and its crap again so must be a booster or master cylinder fault i wouldve though but need some advice.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2007, 12:16 PM   #394
blackers10
blackers10's Avatar
there could be an air bubble between the ABS module and the master cylinder
im told this needs to have the ABS module cycled(bridging some pins)..
to work the air from this section
mines heaps spongy too and i hate it
Old 30-12-2007, 02:42 PM   #395
RspecAU
BA GT-P Owner
RspecAU's Avatar
cheers josh.
From what i have read on this thread the best way to get rid of the spongy feel is to get braided brake lines.
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 30-12-2007, 09:51 PM   #396
sly
Sly like a G6
sly's Avatar
I changed my booster to an AUII one. There was excessive clearance between the booster pushrod and the m/cyl piston, even with the adjuster screw all the way out, giving a long pedal travel before any braking effect. I had to insert a spacer about 7mm long cut from a rod approximately the same diameter as the pushrod. Sweet now.
Sleeper, anyone?
Old 31-12-2007, 07:22 AM   #397
Papa Smurf
Papa Smurf's Avatar
Sly, thanks matey
Old 04-01-2008, 08:07 PM   #398
mikefpv123
hi mate,hope you can help me with the eb swaybar mod you had done, did you have to drill the lower arms out for the sway bar mount.thanks mike.
mikefpv123 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2008, 10:27 PM   #399
JC
JC's Avatar
Yes, new holes were drilled - look on about pg 10 or something of this thread.
Ford Performance Club ACT
JC is online now   Reply With Quote Multi-Quote with this Post
Old 06-02-2008, 12:14 AM   #400
lotus
Well I have decided to upgrade my brakes on the AU1. I will be getting a set of premium brakes,front and rear and all of the front end from a BA XR6 turbo.
Even though I don't need all of the front end, I will get it all so that I can clean and paint all the parts before assembling it into the car. Just makes it easier to do.
With the rear calipers,it was said here that a spacer is required between the caliper and the mounting points on the diff. Does anyone know the correct thickness for this plate. I think 2 or 3 mm was the thickness mentioned.
Also is the sway bar the same for the AU2/3 and the BA's.
Will take my time preparing everything and will get braided lines made and fit while installing everything onto the car.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2008, 10:35 AM   #401
honer
Back to N/A land
dudes, does the BF 328mm rears fit in 17" wheel ?
honer is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2008, 10:53 AM   #402
genebaby
Abuser of Charvels
genebaby's Avatar
yeah, they fit ok on most 17's.
Contraband Facebook
Daily: Tornado MY20 GTI
Retired: Venom BA XR8 - build thread
genebaby is offline   Reply With Quote Multi-Quote with this Post
Old 27-02-2008, 12:42 PM   #403
honer
Back to N/A land
Wow, I went to buy some BF XR Calipers and found out Rotors are like $300 a peice !! Stuff that..
I think I'll just go with the BA Rears with the 303mm. Does anyone have a part number for these Calipers ? My contact at Ford said they are the same listing as the BF XR Caliper but I'm pretty sure this isn't the case.
Old 27-02-2008, 12:58 PM   #404
StealthAu
Who ever quoted you that prices doesn't like you, I could get you a pair of slotted ba rotors for around that
Old 27-02-2008, 01:17 PM   #405
honer
Back to N/A land
Those were "mates rates" prices from for DBA Rotors for the 328mm
BA 303mm were like $50 each for slotted.
I forgot to mention this is for the Rears
Old 27-02-2008, 01:31 PM   #406
mr_xr8
Capri GT/TS50/GTR
mr_xr8's Avatar
wasnt this a sticky???
R32 GTR Rebuild
TS50 Build
mr_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2008, 03:05 PM   #407
honer
Back to N/A land
Alright dudes
I brought a set of Rear BA Calipers brand new. Part number matches my existing AU3 Calipers. So I'm guessing the Caliper Mounting Bracket is the only difference between the 287/303/328 Rear Brakes (Makes sense as Ford told me the part numbers for the 303 and 328mm Rears were the same)
Hopefully I'm wrong as now I'll have the tedious task of hunting down the Support Brackets.
Is anyone able to confirm if they have used the AU Caliper Support Bracket with the 303mm Rears ? I'm assuming most people get the mounting bracket when they get the Caliper off a wreck and thus would never have run into this problem.
Old 11-03-2008, 03:09 PM   #408
genebaby
Abuser of Charvels
genebaby's Avatar
The 328 rears use a totally different caliper to the 303. The rotor is ventilated so is much thicker.
Contraband Facebook
Old 18-05-2008, 04:40 PM   #409
Serge
Serge's Avatar
I have read the thread from start to finish and still a tad confused, I want to upgrade my AUII front brakes to the BF XR6T, XR8 what I need to know is what the diameter of the disk and whether the brake lines are adequate, as someone here mentioned that the territory brakes don't bolt up, also what would I be looking at in getting my hands on the calipers and slotted rotters to suit. Part numbers would be a bonus, cheers, Serge
Serge is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2008, 05:41 PM   #410
sly
Sly like a G6
sly's Avatar
Most here have only gone as far as putting the basic BA brake package onto the AU1 Serge. Best place to go for prices & part numbers would be the Site Sponsor forums - Ferntree Gully Wreckers (FTG) and Race Brakes Sydney. Or get part numbers from the DBA and PBR websites and ring some of the car part supermarkets. Brake lines will be OK, just personal preference to keep them or go braided.
Sleeper, anyone?
Old 19-05-2008, 10:01 AM   #411
XR Lita
XR Lita's Avatar
Rotor part number is RDA7934S for the slotted rotor. It is larger than the AU2 rotors. It measures in at 322mm up front, and the calipers you need are B862-360 and B862-359. Your current lines should be up to the task, as long as they will suit the position of the new caliper. If you need anything further, please do not hesitate to ask.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2008, 02:47 PM   #412
JC
JC's Avatar
All good info, but current lines are too short to reach - you MUST use the AU2/BA brakelines as they are a little longer and will reach the calliper in it's new position - IIRC, the AU1s sit towards the back of the disc, and the AU2s towards the front, or vice versa.
Old 19-05-2008, 02:55 PM   #413
XR Lita
XR Lita's Avatar
But JC, Serge stated that he has an AU2, and wanted to upgrade to BF, hence why I didn't stipulate about the lines
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 19-05-2008, 03:26 PM   #414
JC
JC's Avatar
Doh! Correct you are. The thread is about upgrading from AU1 to AU2 +, hence my mistake.
Old 19-05-2008, 08:07 PM   #415
sly
Sly like a G6
sly's Avatar
Hence my suggestion above, as he doesn't need to change 3/4 of his front suspension as most who use this thread do :
Sleeper, anyone?
Old 19-05-2008, 09:30 PM   #416
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
The caliper and rotor kit that FTG salvage sells here are the BF XR6T/XR8 equivalent. They will bolt straight up to an AUII.
DoreSlamR is online now   Reply With Quote Multi-Quote with this Post
Old 19-07-2008, 06:50 PM   #417
au^dude
au^dude's Avatar
Originally Posted by JC
OK in this pic you got the D brackets what are the other brackets? Are they needed?
au^dude is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2008, 12:05 PM   #418
Stav
Smile
Stav's Avatar
After all that reading my head is spinning!!hehe. Au 1 to AU2 or ba fronts ...Correct me if I am wrong..
2 au2 or ba Uprights
2 lower control arms
au or ba pads
ba calipers.
Sway bar?
Uprights bolt in..calipers bolt in ..then pads go on. Ok what is needed from there.I having trouble down from 170kmph at the track quick enough for my liking.
Old 20-07-2008, 12:18 PM   #419
Mont5.0
Mont5.0's Avatar
au or ba pads
ba calipers.
Sway bar?
longer brake hoses-series2 ones.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2008, 12:43 PM   #420
blackers10
blackers10's Avatar
the big brackets are what holds the sway bar to the chassis rails
you need to drill your own holes thru the rail
