Old 04-06-2006, 01:53 AM   #1
JeffAU1
JeffAU1's Avatar
Default Foot Mat needs re-glueing
Hi all,
My Foot Mat on the drivers side has some un-glued.
How can I restick this ?
Can I clean the surfaces and re-glue ? If so, what glue and where is best to get it from ?
Any tips on how best to do it would be helpful.
:eclipsee_ MY CAR :eclipsee_
JeffAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 02:21 AM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
even using good old silicone would stick it back on no trouble i recon ;) , im actually suprised it has come completely off ! . With a surface area so large it would probably take a while for the silicone to fully cure ( maybe poke a few pin holes in the mat to get air under it and it would cure quicker ), either way it would priobably end up being one of the most durable adhesives in the end despite the curing time because of the large area and not much air to help it cure quickly .
:eclipsee_
Old 04-06-2006, 02:17 PM   #3
chief
FTF Club Moderator
chief's Avatar
The 3M spray on glue is good stuff. Its called Super 75. Just check the numbers because the different number = different use what could stuff you up. It cures in just minutes as well.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 05:39 PM   #4
Burley
CRE.87V
go to any car trimmers ask for contact adhesive...im a trimmer when we get these cases in we usually place contact adhesive on both surfaces wait a few minutes then bond these together...in some cases we have even pulled the carpets out a under the sewing machine we stitch around the heel mat...u buy 2l drums of this for under 100 bucks....take a jam jar in..ull prob pay like 5 or 10 bucks to fill one..this will do the job fine
hope this helps
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2006, 07:26 PM   #5
JeffAU1
JeffAU1's Avatar
hope this helps
yeah thanks man, i noticed that it has stiches around the edges so that is clearly what the last owner has done.
Any recommendations on what adhesive ?
