Old 13-01-2010, 11:52 PM   #1
JG65TE
JG65TE's Avatar
Default Escorts and capris
Ok, Time to pick all of ur collective brains again fellas, Just how much is interchangable off an escort onto a capri ?
The capri I am doing has fairly serious cancer in the front drivers pillar near the top door hinge. (i am guessing they go there a fair bit) , sure I can fab one up but laziness beat old age and i have a case of cbf. I can buy a escort pretty cheap, so i was thinkin of cutting the pillar I need out of it. But what else can I use off the escort ?. Forget drivetrain, Its all good to go. I am talking trims , suspension , bumpers etc ??..
Doc
JG65TE is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2010, 08:48 PM   #2
R0BD0G
R0BD0G's Avatar
i think most of the time people go the other way with suspension (capri V6 struts and gear like that) you will find the capri to be about 35 - 45mm wider than the escort anyway from what i remember
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2010, 08:29 PM   #3
whooligan
whooligan's Avatar
No body parts are interchangeable btwn Escorts and Capris. If you need to replace body sections, I would think it would be much easier to fabricate something new from scratch rather than adapt something from another car thats been out in the elements and/or endured 30+ years of driving on aussie roads.
Old 17-01-2010, 04:45 PM   #4
paul w
L block
paul w's Avatar
Wink
As whooligan said no body parts are the same although you may be able to cut similar size donor parts from an escort if you had one lying around but I wouldnt buy one with the intention to use other parts on the project, apart from tail lights if its a MK1 escort there wouldnt be much to use.
paul w is offline   Reply With Quote Multi-Quote with this Post
